Removing the double sided tape ......
:crossfingers::crossfingers::crossfingers:HELP
I removed the hard plastic rock guards (at the rear door) to repaint them from all the road and rock damage. But now there is a continuous bead of double sided tape residue on the car (painted area). How do I remove it? |
WD-40 should do the trick.
WD40 is great! goo gone and rubbing alcohol will also do the trick without hurting the paint...use a microfiber cloth to get it off, and not something harsh, that can damage the paint...
Some of those tapes leave a very thin strip of something like tape behind, so a razor blade could help.
Mineral spirits works great also.
Thank you
Thank you to everyone, used a combo of a couple of your suggestions, all the "goo" is gun the parts are sanded, primed, repainted and back on...woo hoo
:twothumbs: |
Fishing line used like a saw works....for future reference
eraser wheel you get at a English Colors paint store
they are amazing and easy to use and done nothing flat http://ecx.images-amazon.com/images/...500_AA300_.jpg |
I use a heat gun along with WD-40. Works faster with heat, especially factory double sided tape. Boydie |
| All times are GMT -5. The time now is 02:06 AM. |
