SilverStar replacement bulbs going in!!!
Old Apr 15, 2010 | 01:18 AM
  #91
Deuces's Avatar
Originally Posted by briand
Goose, does your 2007 have DRLs that use the headlight? The way the DRL system works, it causes a faster burnout of bulbs (especially aftermarkets like the Silverstars). I believe this is why GM switched the DRLs back to the turn signal/parking lights on the 2008+ models.
Originally Posted by solman98
Only one's I've seen use the parking lights was the 06 model.
My '08 uses the High Beam as the DRL. This is why I usually shut them off during "Normal" driving.
Old Apr 16, 2010 | 04:43 AM
  #92
ebritt's Avatar
Found this on a site:
"Thank you for your web inquiry and interest in Sylvania SilverStars. The SilverStars are a performance, premium halogen that have a significantly shorter life span than the standard. The shorter life span is directly related to the performance nature of the lamps. The amethyst colored coating on the glass contributes to the crisp white light emitted, but also traps heat inside the capsule, causing the filament to burn out more quickly, thus decreasing the life. Expected life is about a year, and is largely dependent upon your individual driving habits. The life of the product is decreased significantly if it is being used in a day time running light application. Estimated life in a day time running light application is at most 6 months.
You could upgrade to CoolBlue. You would receive a longer life than you would with the SilverStar, but you would again suffer a shorter a life than standard. XtraVision is probably your best option.
Please contact me if you need further assistance.
Thank you,
Heather Kennett"
Sounds like Silverstars are crap.
Old Apr 16, 2010 | 08:22 AM
  #93
spirited driver's Avatar
Thank you,
Heather Kennett"
Well, at least they're honest-
Old Apr 16, 2010 | 08:33 AM
  #94
TomsHHR's Avatar
Originally Posted by jaime_g
Is there a special way to pull out the two 'push in' connectors or do you just use force? I've been pulling pretty hard and it looks like it's going to break. I'm willing to use more force if that's all it takes, but I wanted to confirm if there's a "correct" way to do it.
The bulbs are push-in, the bulb holders twist to the left and pull out.
Old May 16, 2010 | 07:03 PM
  #95
hhr_guy's Avatar
Light went out Sunday, found this on Monday. Replaced both fronts with Silver Stars. Big difference from stock....night and day. Thanks for posting.
Old May 16, 2010 | 08:22 PM
  #96
DirtyJim's Avatar
I love my SilverStar lamps. I live in Williamsburg, Virginia and there is a deliberate lack of street lights (for beautification and light pollution issues), there are a lot of trees and a LOT of deer. After I destroyed the front end of my car running into a deer, it got new Silverstar headlights and Ill never go back. This is on a vehicle other than my HHR, but the difference in light output was enough to warrant the cost, in my opinion. They really do work much better and especially when the roads are wet.
Old May 17, 2010 | 09:58 PM
  #97
ebritt's Avatar
Originally Posted by ymerej_mortsdnil
I was at my local Auto Zone & came across a new product from Sylvania, the Silverstar Ultra...anyone using these yet?!?
http://www.sylvania.com/ConsumerProd...ce/Silverstar/
I used a set of these in my 03 Cavalier LS Sport and was very happy with them. You can definately tell a difference from stock or even the plain Silverstars.
Old Sep 26, 2012 | 06:13 PM
  #98
2008LT's Avatar
After wrestling with trying to push in and lock a bulb for about twenty minutes, I was a wreck. I could not for the life of me figure out why it was so difficult to lock in this stupid bulb! Finally, I realized that the rubber washer from the previous bulb was still stuck in the housing, making it damn near impossible to seat the new bulb. Doh!
Old Sep 26, 2012 | 07:36 PM
  #99
Don't feel bad. You're not the 1st one to do this. I recall some other posts where folks did the same thing. LIVE and LEARN!
Old Sep 26, 2012 | 08:37 PM
  #100
I better get a replacemen set in sstock , my Silverstars are 13 months now , has anybody uncovered a brighter longer lasting bulb yet?
