thingamajig
what is the glovebox on the dash called?? and do the 2 screws in the front let you remove the whole box or is there some other parts to loosen
Dash cubby, collect all, upper bin, junk box. Those two screws will allow you to remove it. |
thanks buddy, seems like a spring has sprung on one of the back hinges, maybe a trip to a u-pull-it place for a new used one
just did a quick e-bay, found 'em
It's the rubber bumpers that do the springing.
Originally Posted by donbrew
(Post 849233)
GM calls it COMPARTMENT. Instrument Panel It is a unit, the whole thingamajig. Follow the link, there seem to be 3 part numbers, 3 colors.
(Post 849239)
However, as I pointed out: it is the rubber bumpers that provide the "spring". Mine always tried to wander off of the spot they are glued to. I just moved them back periodically.
https://cimg0.ibsrv.net/gimg/www.che...7535713a03.png |
i need these stupid little things as mine are starting to stick and wont allow the bin to open sometimes.
$7 for two but shipping to canada is anywhere from $20-45 haha wtf |
