Wheel Bolt Patterns
Old Mar 1, 2007 | 04:28 PM
Nazramoth's Avatar
Wheel Bolt Patterns
I know the Bolt Pattern on the HHR is 5x110.
However I am curious if there is any bit of leeway on these specifications and how far off that 5x110 could one go, and still have a safe fit?
Or is it strictly 5x110.
For example; would a wheel that is listed as having a "5x4.72 or 5x120" bolt pattern fit with a little work?
Old Mar 1, 2007 | 04:45 PM
TruckSHOP.com's Avatar
Former Sponsor
Short answer, no.
It isn't possible to make that work with just "a little work"
If the wheel has covered lugs you may be able to have it drilled 5x110 in-between the existing bolt patter. Wheels can also be "filled and drilled" or use inserts to change the bolt circle. But those options are best left up to professionals.
Old Mar 1, 2007 | 04:46 PM
Nazramoth's Avatar
Thats pretty much what I thought; but wanted clarification... and thanks!
ScottyPimpin
2.0L Performance Tech
24
Jun 4, 2013 06:04 PM
Electrical Master
27
Jan 5, 2012 11:28 PM
8t7vette
Aug 2, 2010 02:09 PM
andyb
Tires & Wheels
Nov 20, 2009 12:57 PM
fubar
Feb 20, 2006 02:13 PM
