Xenon HID Kit on an HHR
I would like to buy an Xenon HID Kit for my 09 HHR Panel, I'm sure other owners have already installed them, which kit would be recommended.
Would these lights damage the inner portion of the light after awhile.
Just make sure that the light element itself (a coil on the halogens, a gap between the rods on the HID) lines up properly in the reflector housing or you are just making your headlights into beacons and not shining on the road (but into oncoming drivers eyes).
Seth
Seth
go for it man, www.vvme.com is a great place, and they quick, probably better than getting a cheap setup off ebay like i did the first time, and went with them when the cheap ballast finally went out, also a cheap kit can interfere with your radio causing static on some stations, so go for a decent kit from them. this would be for your headlights
and This for your foglights if you got/want it.
That link for the fogs show an H10 bulb. FWIW, HHR's use a H11 bulb for the fogs (well the SS's do, IDK if LT1's or LT2's use an H10 for the fogs) and the headlight bulbs are H13. You'll need a bi-xenon bulb for the headlights.
Later
Allex
Later
Allex
