12inch subs on stock radio????
Old Apr 14, 2010 | 07:42 AM
GrotesqueFetus6's Avatar
Okay, so I got 2 - 12inch subs and 1100 watt amp
Can I run this on a stock radio ?
I'm just looking for bass
Old Apr 14, 2010 | 07:48 AM
prod's Avatar
If the amp has high level speaker wire inputs, you're good to go. Just need a wiring kit. I also used a fuse adapter to get a turn on signal from the fuse box.
Old Apr 14, 2010 | 07:51 AM
I'm not sure at all, how do I find that info out?
Also you might have to explain some of this to me, I'm not much of an audio person lol
And thanks for the help also
Old Apr 14, 2010 | 08:51 AM
hugheshhr's Avatar
If the amp doesnt have high level inputs, you can use whats called a line out converter. They accept speaker wire input and convert them into rca outputs to connect an amp to. They generally range in price from 15 dollars to 25ish. Any good reputable shop can guide you in the right direction.
Old Apr 15, 2010 | 06:40 AM
Thanks, ill go up to an audio store, I'm sure there going to wanna con me in to buying an aftermarket radio lol but ill tellem noooooooz
longislandhhr09
Apr 23, 2009 04:33 AM
joshua_arndt
Sep 26, 2008 07:38 PM
06Daytona
Jul 22, 2007 02:33 AM
HHR PNOY
Apr 6, 2007 09:39 AM
