aftermarket cd player???
Old Mar 4, 2010 | 10:01 AM
prod's Avatar
Originally Posted by biglefthhr
yes however, where is the correct location to connect that 12v switched wire in the fuse box does anybody know?
I used an "add-a-circuit" connector on the sunroof fuse. Just plug it in and it has a power wire coming off it, no hassle with splicing or soldering to the existing wiring.
This functions with the retained power accessory circuit for a while after the car is shut off.
Old Mar 4, 2010 | 11:46 AM
biglefthhr's Avatar
THNX, I have the idea now just gotta use the window switch or somthing, I have no sunroof
Old Mar 4, 2010 | 11:50 PM
prod's Avatar
Neither do I. Thats the point, you still have power to the fuse placement for a sunroof, so thats the perfect one to use. If you cant get an add-a-circuit, you can just solder a wire to a fuse and stick it in there.
Old Mar 5, 2010 | 12:01 AM
biglefthhr's Avatar
DUDE, got the add a fuse worked perfect I used fuse port #21 works great and it stays on until you open the door thanks so much!!!
Old Mar 5, 2010 | 01:56 AM
prod's Avatar
No problem, glad I could help ya.
Now, I have a question for you. Which harness did you use, and do you have onstar?
Im considering an aftermarket deck, Id like to keep the onstar and chimes so I got the metra lan-04 with the RCA plugs, but there is conflicting info as to whether this is usable with the onstar or the pioneer system.
Old Mar 5, 2010 | 03:02 AM
biglefthhr's Avatar
ok the one I got was a metra but it deleted the chimes and the blinker click, no I dont have onstar, I it seems to work fine once I figured it all out the dimmer does not work tho not sure why its hooked up to the correct wire the whole system dims just not the radio, the one you have comes with a little box right, from the research ive done on here it seems to work fine, the best thing to do is go slow and try it, oh have you checked cruchfeild I heard they really work well and you put your cars info in and it sets you all up with what you need....hope this helps!!!!
BreakStuff
Mar 3, 2014 09:35 PM
johouse05
Aug 18, 2010 01:20 PM
tleslie79072
Jun 24, 2007 05:41 PM
crowbar
Jul 28, 2006 07:28 AM
