amp suggestions
Old Jun 25, 2013 | 09:24 PM
skyline26's Avatar
amp suggestions
can anyone suggest an amp that is better than the stock one? i want to keep the stock woofer but dont want to blow it, cuz im sure the woofer can take a bit more power than the stock amp gives out
Old Jun 26, 2013 | 11:32 AM
dr_fosg8's Avatar
I have been considering this myself. I am looking at something like this, http://www.crutchfield.com/p_206PX2K....html?tp=35834
Should add just enough to make the stock sub a little louder and I am thinking it will fit nicely down by the battery.
Old Jun 26, 2013 | 03:32 PM
MsBecky's Avatar
I know a small amp that has plenty of real power and also have a very good price . You can pick them up on Ebay from the manufacturer . It is Phoenix Golds repair and service center , so they come with a warranty . It will smoke that little amp from crutchfield ..... It is 125.00 dollars US . Leave the factory amp to power your other speakers .....
I had one , and now have another one along with its big brother . For the dollar per watt value , this little amp is hard to pass up .
Greg
http://www.ebay.com/itm/Phoenix-Gold-Xenon-X100-2-2-Ch-Amplifie-300Watts-90Day-Warranty-Tech-Support-/300810270256?pt=Car_Amplifiers&hash=item4609b07630
Old Jun 26, 2013 | 04:19 PM
dr_fosg8's Avatar
I could be wrong and someone please correct me if I am. The factory sub has dual 2 ohm voice coils resulting in a 1 ohm mono load. That PG amp msbecky listed showed a 2 ohm minimum running bridged which would be no good for stock sub.
Old Jun 26, 2013 | 04:35 PM
skyline26's Avatar
ya its a dual..but becky said to run it along with the stock amp..
dont have the stock amp anyway so that wouldnt work..just need to find a decent mono
Old Jun 26, 2013 | 04:41 PM
prod's Avatar
You should be able to run the stock sub at 4ohm by wiring the voice coils in series, then any amp should handle it. Theres a couple kenwood amps on the ont cobalt forum for $40.
Old Jun 26, 2013 | 04:45 PM
MsBecky's Avatar
Dual 2 ohm sub .... series = 2+2 = 4 ohms ..
Greg
http://m.seimg.net/product/img/subwo...ch_bridged.jpg
Old Jun 26, 2013 | 07:22 PM
dr_fosg8's Avatar
Gotcha, I was under the impression you had the full pioneer system and wanted to disconnect the factory sub and use an amp with a little more power just for the sub and keep the factory amp for the doors still.
Carry on.
Old Jun 26, 2013 | 07:33 PM
skyline26's Avatar
im always so weary on buying used amps..never know what they've been through or if they will cut out the next day
Old Jun 26, 2013 | 08:24 PM
dr_fosg8's Avatar
Also, just about any major brand amp will most likely be better than the stock amp as far as driving a subwoofer.
debsmojo
Feb 16, 2010 01:10 PM
NOSbreather
Tires & Wheels
24
Dec 28, 2009 05:48 PM
thorn11166
Sep 14, 2009 03:32 PM
ecl
South Mountain
Nov 9, 2008 01:38 PM
Desert Coyote
Aug 4, 2006 01:15 PM
