Antenna Connector
Antenna Connector
OK - I have not changed a radio for a couple of years, and the last time I did I was confronted with GM's mini motorola plug... Now, I think I've got to deal with that again so I get the mini-motorola stuff... Nope.
I've never seen an antenna connection like the one that is on the HHR.
I'm trying to add a second radio to the same antenna, so I need to adapt from whatever to motorola, insert second cable, and back again to whatever.
Any suggestions?
Any suggestions?
Originally Posted by Black Beauty
Be ever so careful. Another forum member had problems with the antenna, never did really find out the end result. The dealer tried several times to correct situation, maybe did.
Be Careful !!
Be Careful !!
Hope it helps,
