Is it the antenna that sucks?
Thanks. So no need to worry about a fuse, as long as the radio turns on.
Huh. The speaker amp would use a LOT more power that an antenna amp. Or is it just a signal or powering a relay something, right?
Today yesterday I found the antenna loose. Again. Used a little extra effort to tighten it, then had to rush off before trying it.
SpaceCowboy
Mar 6, 2018 04:32 PM
