Capacitor Charging
Capacitor Charging
I have succumb yet again to the power of this information highway and those that drive it.
I left work early today to get a headstart on installing the amps and capacitors in the spare tire area. I have the wire run and was just about to hook up the Capacitors when I remembered they needed to be "charged" first. I do know of a few ways that charging the system can be done but herein lies my problem(s)..
A) Disconnect audio system fuse and use a 30Ohm resistor (usually comes with the capacitor but it didn't on mine for some reason)
B) Same as above except where a 30Ohm resistor isn't available use a 2 wire test light and wire it into the fuse line.
C) Accept my fate of being shocked (which isn't all that bothersome) but take a chance at frying the "goods". The shock/spark is from a super fast charge of the capacitor.
Since I lack a 30Ohm resistor and test light, getting shocked would be a walk in the park assuming I didn't fry $500 in Capacitors and even more in Amplifiers.
Young fellow seeking guidance.
Dont use 2 brand new capacitors? That's like saying, "Don't drink the Patron because you have no Redbull."
Voodoo 3.0
Voodoo 3.0
Your battery charges the cap so whats the point? If your having problems with your audio equipment drawing too much power it's better to upgrade to multiple batteries and a high output alternator. But of course it's a matter of opinion because some people swear by using caps.
Capacitors are for fast draws of current. You can add as many batteries as you want, but without a capacitor, one would turn those batteries into a pile of plastic in less than a year.
Please understand that with over 5000 watts of power, another battery and a 140/160/200 amp isn't going to solve all the issues.
CHitownHHR
Be patient and wait until you get the 300 ohm resistor or test light -
I'm an Electronics Tech not an installer but I think the idea behind using a 300 ohm resistor or test lamp in series on the line fuse is primarily for safety - just in case your cap's are defective (have an internal short). This is to prevent a battery explosion and injury to yourself.
