change dome light
2008 ls. I would like to change my dome light to an aftermarket led
Unit. Mine is broken and amazon sells a led unit for $17. So how would it wire up. Existing dome light has black ground, grey ?, and blue/grey always hot. So if you are wiring up replacement light what Goes where? Any help much appreciated |
The black is ground , the always hot is for a switched at the light feature and the grey? Is for the door switched feature
Originally Posted by Oldblue
(Post 799865)
Originally Posted by jbowles49
(Post 799868)
Many thanks!!!
The wiring diagram shows that the grey wire goes to the control switch. I assume that the control switch would be the dimmer control knob located on the center waterfall panel.
Dimmer switch knob turned to the far right position powers on the interior courtesy lamps. |
Don't forget the lights are controlled by the RAP.
Don't be coming back complaining that the lights glow dimly all night long. The answer lies with the search tool.0 |
(Post 799877)
Dimmer switch knob turned to the far right position powers on the interior courtesy lamps. Many thanks for assistance. John |
The lights are controlled by the BCM, it supplies ground.
