change dome light
Old Mar 27, 2016 | 02:04 PM
jbowles49's Avatar
change dome light
2008 ls. I would like to change my dome light to an aftermarket led
Unit. Mine is broken and amazon sells a led unit for $17. So how would it wire up. Existing dome light has black ground, grey ?, and blue/grey always hot. So if you are wiring up replacement light what
Goes where? Any help much appreciated
Old Mar 27, 2016 | 02:31 PM
The black is ground , the always hot is for a switched at the light feature and the grey? Is for the door switched feature
Old Mar 27, 2016 | 02:35 PM
jbowles49's Avatar
Many thanks!!!
Old Mar 27, 2016 | 03:46 PM
jbowles49's Avatar
Originally Posted by jbowles49
Many thanks!!!
Test light does not show power on door switched grey. Fuse is good on interior lights #27 in box. Any ideas?
Old Mar 27, 2016 | 04:28 PM
The wiring diagram shows that the grey wire goes to the control switch. I assume that the control switch would be the dimmer control knob located on the center waterfall panel.
Dimmer switch knob turned to the far right position powers on the interior courtesy lamps.
Old Mar 27, 2016 | 05:14 PM
Don't forget the lights are controlled by the RAP.
Don't be coming back complaining that the lights glow dimly all night long. The answer lies with the search tool.0
Old Mar 27, 2016 | 05:15 PM
jbowles49's Avatar
Think I figured this out. Wiring hot lead into accessory light postive and negative light lead into grey wire allows dome light replacement to function as per factory. Shut door light dims in 20 second. Open door light comes on.
Many thanks for assistance. John
Old Mar 27, 2016 | 05:32 PM
The lights are controlled by the BCM, it supplies ground.
fastsuv
"How To" Tutorial Library
77
Jul 28, 2020 10:57 PM
billdaly
Apr 30, 2008 08:02 PM
Velocity12
Feb 1, 2007 08:51 PM
bgnoz
Jul 29, 2006 12:31 PM
Skully
Mar 18, 2006 06:34 AM
