clipping?
Old Oct 10, 2006 | 07:27 AM
longhorn's Avatar
clipping?
Allright audio gurus, got a quick question. I installed a 12" kicker comp and a kicker zx100.2 a month or so ago. I keep hearing warnings about "clipping" what is it, and what does it sound like? The amp has been tested at 124 watts, sub handles 150. I am running about 3/4 gain, and a tad of bass boost to compensate for the stock HU cutting bass at higher volume. It sounds allright, but it doesnt seem to hit hard ( I know, I should have bought a comp vr and bigger amp, but funds said no ) or quick. If I listen to rap or techno (chemical brothers) it sounds great, if its rock, it's not so good. Any suggestions would be great.
Old Oct 10, 2006 | 02:54 PM
mudbilly's Avatar
if it sounds good (hits hard) with one style of music (rap) but not another (rock) i'd figger that the rock music just doesn't have the bass in from the time it was recorded.......
Old Oct 10, 2006 | 07:31 PM
Lefty613's Avatar
ok well first link...
http://www.subwoofertools.com/forum/setgain.asp
always set ur gains properly... its not a volume button... get rid of the bass boost ( it will ruin ur speaker down the line ) test tones can be found on that site...
2nd link
http://www.bcae1.com/amplfier.htm
you could read up on how it all works there
3rd link
http://www.bcae1.com/2ltlpwr.htm
this one will explain clipping
as far as rock goes... if u mean bass i think u mean the bass drum.. there all tuned differently, when were talking subs we mean 80hz n lower (give or take).. u could always get stronger mids if u wanna feel that strong hit of the kick
Old Oct 10, 2006 | 08:55 PM
longhorn's Avatar
Excellent! getting out the multimeter tomorrow and setting the gain. downloaded some test tones 40hz, 50hz and 30hz. Thanks for the info. Why is bass boost bad? the audio shop told me that it could cause distortion in the bass while using the oem HU, but never said it would cause problems
Old Oct 10, 2006 | 09:59 PM
Lefty613's Avatar
well put it like this....
u set ur gain with everything at zero with a 3/4 volume with a 0db test tone... now u kno that when u blast ur music u wont clip... so lets say u have a flat response... when u raise ur bass boost it creats a peak (most the time) at 40hz ... so we went from this ---------- to this __/\__ we had jus balance our gain but u are now sending a stronger 40hz signal.. so this will induce clipping in the 40hz range...
plus to get more musical u want a pure unaltered signal... the bass boost will mess **** up.. lol
look i tuned mine like this.. i droped the LOW from 0 to -2.. i dont need my door speakers workin this hard cus i have a sub now... then i set my gains... now i listen to music with the LOW at -4... sometimes u dont need that much but u could always go up a lil when u need more... and if i drop the bass to the lowest point.. something like -8 sub sounds like door speakers ( i use this while parking and i turn the volume down...)
also its important to remember these are subs.. iv had friends cross there sub at like 140hz with at a 12/db oct... eventually from the subs playin so high they burnt the voice coil...
Old Oct 11, 2006 | 06:52 AM
longhorn's Avatar
so your saying if I set the gain with the bass on the head unit on the - side then I can basically use the head unit to add bass when I need/want it, which would also eliminate distortion in the doors ? makes sense. the sub is crossed at 80hz
Old Oct 11, 2006 | 11:53 AM
longhorn's Avatar
After doing some looking, I found I missed an input (was late when I installed ) so I wasnt bridged. Sounds alot better, hits a ton harder. The amp was certified at 124w so I have the amp putting out 22.5v, which is what the link told me to do. I tuned it with the bass on the head unit in the - area, and it sounds excellent
Old Oct 11, 2006 | 05:39 PM
Lefty613's Avatar
ohh see i thought u were running it bridged... didnt even think to ask that.. im glad it turned out better...
let me kno when ur ready to upgrade... lol
Old Oct 11, 2006 | 06:09 PM
longhorn's Avatar
hehe, so did I! I am going to start looking for a new HU soon. Would like to have one that plays MP3s and has the input jack like the stock unit, just sound better
Old Oct 11, 2006 | 07:35 PM
Lefty613's Avatar
the stock hu plays mp3 cds
