Harness for aftermarket HU's??
Is this what we need to install aftermarket HU's? I thought there wasnt one out yet?
http://cgi.ebay.com/06-Chevy-HHR-Imp...QQcmdZViewItem
Originally Posted by MrCrusha829
I will let you know by the end of the week if it works or not. I just ordered it last week.
Also...
to chevyhhr.net We look forward to seeing you around the boards and getting to know you.
one member that I know of ordered this package and got it to work. They just had to move around some wires to fit the HHR's wiring. There's also a post here with the wiring diagram for the radio connections.
I have the exact harness and wired it up in May. The problem is the GM Lan module isn't included with that (obviously) and none of the other GM modules will work, not even the Cobalt/Impala/Trailblazer (I tried all three).
The harness works, don't get me wrong there, but lacking the GM Lan mod signal sounds, door chimes, etc. will still not work.
Re: Aftermarket
That link was for the wiring harness needed for upgrading to an aftermarket head unit. It is a little spendy... I asked the installer if the only purpose of this was to make the door chime through the sound system. He informed me that this module is also connected somehow with the oil life meter. I guess I am going to have to save some more pennies and wait to buy it...
Originally Posted by Gooch
Is this for the HHR? I was in Best Buy about a week ago and they checked and still had no time frame as to when they would be out.
Mike...correct me if I'm mistaken.
if you install an aftermarket head unit you can use the harness and rewire it, or you can just tapp the factory one like i did. If you dont mind losing your chimes and warnings then go for it. as for losing anything on the DIC, you dont, i havent, socal's hasnt, and there are others here that havent. if you have onstar, you will loose that. pioneer, if i remember CJ correctly, while have an interface out some time in october for onstar.
