Help trying to install headunit
Old Dec 8, 2013 | 12:52 AM
pizzajon555's Avatar
I am trying to install a boss bv9370nv, i have ran the speaker and the navigation and thought i hooked up the wiring harness correctly but i have absolutly no power. the kit came with a lonly red wire with a wierd thin to wide electrical end and othe othe end of the wire was just bare. any sugetstions would be great???
Old Dec 8, 2013 | 01:00 AM
Lucky's Avatar
Welcome to the site. I do not have very much info on aftermarket radio installs. I'm sure that others will chime in here soon. In the mean time You can find a lot of info using the search box at the top of the page.
Old Dec 8, 2013 | 09:38 AM
A) did you look at the directions that came with the unit? Or gone to the manufacturers website?
B) did you use the SEARCH box at the top of this page? Use "radio install".
This particular problem has been covered many times, as recently as this week.
Old Dec 8, 2013 | 10:45 AM
SpaceCowboy's Avatar
did you buy a wiring harness kit? red is 12v switch power and yellow is 12v constant power...both wires + ground will need to be hooked up before it turns on
Old Dec 8, 2013 | 10:54 AM
thunder94's Avatar
there is no 12 switched power at the factory radio harness.
You will have to extend the red wire from your new deck to the large 12g green wire at the factory fuse panel in the front of the center console.
Old Dec 8, 2013 | 02:58 PM
thanks for the friendly welcome!
Old Dec 8, 2013 | 02:59 PM
that makes me feel very welcome here, thanks donbrew
Old Dec 8, 2013 | 03:18 PM
You will have to extend the red wire from your new deck to the large 12g gwire at the factory fuse panel in the front of the center console.
so not the fuse box under the hood? and run the red wire through the firewall? would that work? assuming i can find a fuse that is switched power in that fuse box
Old Dec 8, 2013 | 03:24 PM
i purchases a wiring harness from the stereo shop here in rochester, they told me it would be a plug in and go situation. that has not been the case. BUT the harness does not continue the ground, red, or yellow wires! which from what I can tell yellow needs a direct connection always with power, red needs to switch on with the key turned, and then ground obviously grounded.
I am about to try to run the red through the fuse box and through firewall i think, and now that i'm thinking i could connect the yellow directly to battery if it was not in the trunk. so i will have to find a wire that is constant power and splice the yellow into that?
does that make sense?
I really appreciate you taking the time to help me and not just sending me off to another website. THANK YOU!
Old Dec 8, 2013 | 04:44 PM
thunder94's Avatar
No No No, not the one under the hood, under the front of the center console like I first said. From the pass side, remove the fuse panel cover, should see all of the fuses and a couple of wiring harnesses.
Green wire should be hot when key is on only, tap into that.
