HHR Stereo Mounting Kit...
Old Jan 24, 2006 | 04:05 PM
  #31
snova031's Avatar
I'm not so sure on the harness...I don't know if GM changed anything in 06, but from 02 and up you needed an interface for the chime and acc. power.
That is what the radio harness looks like...2 harnesses and the antenna plug. Not sure what wiring harness will work with it from Metra...
Old Jan 24, 2006 | 04:11 PM
  #32
captain howdy's Avatar
I haven't seen a chime module that will work with the 2006 HHR yet, but yes you will need one if you want to keep them.
Old Jan 24, 2006 | 04:13 PM
  #33
wheelsee's Avatar
and the chime module is the thing that will beep at me if I have low fuel, dont put my seatbelt on, or have "ice possible"?
-wC
Old Jan 24, 2006 | 04:25 PM
  #34
Yup, they are all linked together through the stereo system. The chime module is an interface that you wire into your stereo set up to retain those features.
Old Jan 24, 2006 | 04:29 PM
  #35
wheelsee's Avatar
so the DIC will still work then?
-wC
Old Jan 24, 2006 | 04:31 PM
  #36
snova031's Avatar
There's an interface that Metra makes that lets you retain the information center through an aftermarket display (goes under the DIN radio opening on the dash kit.
I haven't received the new Metra catalogue but I have seen it in an ad in my 12 volt newspaper
Old Jan 24, 2006 | 04:33 PM
  #37
wheelsee's Avatar
ok so hold on...when i change out the radio my display underneath the speedo is gonna stop working?
Old Jan 24, 2006 | 04:36 PM
  #38
snova031's Avatar
I'm not sure to be honest with you...I've only seen the Metra ad
Old Jan 24, 2006 | 05:28 PM
  #39
SoCalHHR's Avatar
No it won't. Everything but the chimes will still work. I pulled mine out today:
If you have a 2LT, your steering wheel controls are connected to the DIC, so perhaps there could be some issues there.
On my 1LT there was no problem driving the HHR with no stereo installed.
Old Jan 24, 2006 | 05:31 PM
  #40
wheelsee's Avatar
any chance of a how-to coming from you about the removal of the old radio...
-wC
