ID3 data not showing up correctly
Old Sep 16, 2015 | 02:57 AM
bugo's Avatar
I just bought a 64 GB thumb drive for the HHR I've had for a few days. I put about 8000 songs on it and am in the process of getting it set up properly. I wanted to listen to a certain album so I went through the menu. I selected artist - album - and the first song. The song played just fine but the readout on the head unit listed the artist and album as unknown. I checked the ID3 tags and both ID3v1 and ID3v2 tags are correct. Which ID3 version does the head unit read? ID3v1, ID3v2, ID3v2.2, ID3v2.3, ID3v2.4 or another one? I removed all the album art from every song on the USB drive and I'm about to go see if it made any difference. I'm slowly working the bugs out of the system and if I can figure out what is going on here I'll have most of them worked out.
Old Sep 16, 2015 | 03:09 AM
bugo's Avatar
Looks like removing the album cover art from each MP3 corrected that situation. Now the issue I'm having is that the artists are not in alphabetical order. The first 2 artists in the list start with a C and the next several artists start with A, B, C, D...etc. Then it will jump around and the next artist will start with an R and there will be a group of artists in correct order and then it will start with a, say, G. How do I get all the artists in alphabetical order?
Old Sep 16, 2015 | 07:54 AM
oldracer's Avatar
You did not say which head unit you have so I am guessing it is the factory one but in any case the head units seem to have their own way of reading songs on a USB drive. I have a Pioneer unit in my 2007 LT2 and it reads them in the order they were written onto the drive??!! The slightly earlier model I had in my F350 read them in alphabetical order......go figure. I think it will take some experimenting to see how they are read and then lay out the files on your computer before you load the drive.
Old Sep 16, 2015 | 08:37 AM
Gone are the days of just turning on the radio and listening to what ever stations were available and what Al or Casey were spinning, making a dedication to all the gals out the in radio land !
Old Sep 16, 2015 | 11:43 AM
JerseyJames's Avatar
Don't know if this is the problem, but for reasons unknown, an extra "space" or 2 occasionally gets in front of the visible alpha -numeric characters. You may not recognize them being there, but computers see them and orders them in seemingly wonky order. Just a thought
Old Sep 16, 2015 | 02:25 PM
sinabu's Avatar
I have the same issue. It tends to just put the folders in there how ever it wants them. It was sorted by alpha the very first time I used it but after adding /removing folders over the time it just tacks new ones to the end etc. Eventually it's just stays out of order and I learned to live with it.
I even formatted the drive and reloaded the mp3s and I ended up with the same exact folder layout as before so I'm assuming the radio is holding it in memory.
Clearing the hidden files on the drive that the radio writes seemed to move things around some but still no rhyme or reason that i could find out.
Old Sep 17, 2015 | 01:43 AM
bugo's Avatar
I figured out how to put the artists/folders in the right order. Download drivesort and follow the instructions at:
How to Sort Music on Your Flash Drive for Your Car Stereo
I still haven't been able to figure out how to make it correctly read certain albums' ID3 data.
Old Sep 17, 2015 | 03:30 AM
bugo's Avatar
Now it's playing songs in the correct order, but it will start in the middle of the album. It will play track 7, 8, 9, etc...then play track 1, 2, 3, up to 6 then play the next album.
Old Sep 17, 2015 | 06:38 AM
sinabu's Avatar
Good Find I'll just leave mine be, I'm used to it being out of order lol
Old Feb 9, 2016 | 05:54 AM
bugo's Avatar
I've posted this elsewhere. It seems to work very well other than a few gltches.
I have found a way to make the GM stereo with a flash drive plugged into it play songs in the correct order. It took a lot of trial and error and a lot of time, but I think I figured it out. The process is very tedious but if you do it correctly, your music should be easier to access.
First, download Drivesort at Anerty's Lair - DriveSort and download Mp3tag at Mp3tag - Download and install the Mp3tag program. The Drivesort program is downloaded as a zip file. Extract all files and use the drivesort.exe that is included in the extracted folder to open the program. It is an executable file and doesn't need to be installed.
Create artist folders in the root directory. Then create folders with the album name in the second folder. This second folder is where you want to put your MP3s. If the album has multiple discs and you want them to be separated, create another subdirectory for the discs and put the MP3 files in it. Make sure your MP3s have good ID3v1 tags with at least the artist, album, and track number (the track number is very important.) Once all of your files are sorted on the USB drive, open Mp3tag and under the Directory on the right, enter the drive letter and a colon and backslash (mine is E:\) Give it a while to read all of the files in the folders. It can take a while. It takes about 30-45 minutes on my 64GB thumb drive. You don't have to stay with the computer while it loads the files, so it's a good time to do something productive.
Selecting the root drive will force Mp3tag to read all of the files on the entire thumb drive, even the files within subfolders. Once it loads all the files, select all (control-A) and hit alt-T. A window will pop up with a square on the right that says Cover on the bottom. Hit the X next to the square then click on OK. The word "Cover" should disappear. This is done to delete the album art within the MP3 files which can interfere with sorting and is unnecessary since the GM stereo doesn't show album art. Once this is done (it will take a long time) select all again and click on Convert in the menu at the upper left side of the screen. Select Tag - Filename and inside the format string box type (or copy and paste) "$num(%track%,2) %title%" without the quotes. Then click on OK. This will rename the files to "(track number) (song title)". Example: "02 Scentless Apprentice.mp3". This won't take nearly as long as loading the files into MP3tag or removing the cover art. This will cause the songs to be sorted by track number without having to manually make a playlist.
Go into Windows Explorer and click on Tools and then Folder Options and click on the View tab. Under Hidden files and folders, the radio button should be set for Show hidden files, folders, and drives and there should not be a checkmark next to Hide protected operating system files. When you are through with setting up the flash drive, you will want to go back and set the radio button to Don't show hidden files, folders, or drives and make sure there is a checkmark next to Hide protected operating system files. Next, go through each folder and subfolder and delete any files that aren't music files (images (mostly .jpg files), .ini files, playlists, .txt files, .cue files, .m3u files, .url files and basically anything that isn't an .mp3 file (or whatever format your songs are in.) At this point your music should be in the correct folder but the artists might be out of order and the tracks on each album might be out of order as well. It is tedious, but so is this entire process.
Now open Drivesort. Click the first button from the left and select your thumb drive and click OK. Select the drive with the letter, and not the Disk# line. Then click on the arrow on the third button from the left and long name sort. Then click on the arrow again and select order and either ascending or descending, whatever your preference is. 99 times out of 100 you will want to pick ascending. Then click the arrow again and select Directories and select your preference. Now click on the arrow on the 4th button from the left and make sure subdirectories is unchecked. Now Drivesort is set up and the settings are saved. The next time you open Drivesort you won't have to set the options up again.
Now select the root directory of the flash drive and click on Folder - Sort to sort your directories in alphabetical order. Next you'll want to click on the arrow on the 5th icon from the right and make sure that there is a checkmark next to Playlist Mode. Now click on the individual artists' folders and rearrange the folders in whatever order you want them to come up in, or click Folder - Sort to automatically sort them in alphabetical order. I sort my folders in chronological order by the year of release.
Now click on Folder and Save. This is very important. Now you're going to want to click on each artist and drag the folders in the order you wish and click Folder - Save and go on to the next artist. Repeat and rinse. This is very tedious and time consuming. Click Folder and Save and you're done!
Be sure to set the radio button under Tools - Folder Options in Windows Explorer back to to Don't show hidden files, folders, or drives and make sure there is a checkmark next to Hide protected operating system files when you get through with the process.
Make sure you set aside enough time to do this because if you have a lot of music, it will take several hours.
An alternative is to not to name the files in the format "04 Alone + Easy Target.mp3" but name the files using just the song title and going into the folders for each album and using playlist mode, dragging the files in whatever order you want to use. I don't recommend this as it would be extremely time consuming, but if you have a smaller drive it might be worth it.
If you do this correctly, you should be able to plug your USB drive in and the artists should be in alphabetical order, the albums should be in chronological order, and the songs should be in order.
Here's more information on drivesort:
http://techmadeplain.com/2014/how-to...ve-car-stereo/
I hope this helps. I hope I explained it eloquently and that the instructions are easy to understand. If you have any further questions, feel free to ask.
If you find these instructions to be helpful, feel free to post them to anywhere on the Internet, namely message boards for different GM cars. I don't mind if you modify the post to make it make more sense.
whopper
0
Jun 30, 2014 02:21 PM
Zagohhr
Maintenance and Upkeep
28
May 6, 2012 09:49 AM
urbexHHR
13
Nov 21, 2009 10:58 AM
edraws
Nov 1, 2007 03:45 PM
Dredd9799
May 14, 2007 04:35 PM
