Just started losing sound this morning.
Hi guys. 2006 hhr lt with pioneer system. This morning I jumped in the car to leave for work ask had very little sound. Almost like when you don't plug an auction cable in all the way. Very faint. I was able to get everything back after a little tinkering. It still cuts out from time to time though. Sometimes one speaker, sometimes most of them. It varies. It almost seems as if the amp isn't getting enough power to push them all. Yesterday I replaced the washer nozzles. The wire that runs along the edge of the cowl seems like it very well may be the culprit. Does anyone know what this wire is for ? I haven't been able to find anything. Haven't had time to get in there today either. Thanks in advance for any info!
I moved your post to a new thread.
I don't know of ANY wire that is supposed to be anywhere near the cowl. Maymbe post a photo? |
Most likely culprit is you need new speakers. Over time the connectors rust and sooner or later they just stop working. I replaced my front two over the summer. Usually they don't all go bad at once though. Might do a forum search I though I've seen posts about having to replace the entire head unit.
Not sure what wire by the cowl you are referring to, but it's not for the audio system. Unless someone rewired things. |
Wire
Originally Posted by donbrew
(Post 856659)
Wire
Originally Posted by Doc brown
(Post 856664)
That is part of the under hood wiring harness. I think it goes to the washer pump.
