Just started losing sound this morning.
Hi guys. 2006 hhr lt with pioneer system. This morning I jumped in the car to leave for work ask had very little sound. Almost like when you don't plug an auction cable in all the way. Very faint. I was able to get everything back after a little tinkering. It still cuts out from time to time though. Sometimes one speaker, sometimes most of them. It varies. It almost seems as if the amp isn't getting enough power to push them all. Yesterday I replaced the washer nozzles. The wire that runs along the edge of the cowl seems like it very well may be the culprit. Does anyone know what this wire is for ? I haven't been able to find anything. Haven't had time to get in there today either. Thanks in advance for any info!
Most likely culprit is you need new speakers. Over time the connectors rust and sooner or later they just stop working. I replaced my front two over the summer. Usually they don't all go bad at once though. Might do a forum search I though I've seen posts about having to replace the entire head unit.
Not sure what wire by the cowl you are referring to, but it's not for the audio system. Unless someone rewired things.
Wire
Wire
just felt as though it wwas weird. Zero problems before this! She did sit for half a year though. Any idea where the power feed for the amp starts? I looked at schmeatics but I'm not very good with them yet.
