Kicker Amps, subs and speakers
Since we're on the subject of Kicker boxes etc. I have an old Kicker SS12 box (2-12's w/horns & tweets) sitting out in my garage.
Anybody know any info....is it worth anything??
(pretty old school by today's design) I did a web search but came up w/squat.
BTW, Adam... nice radio/head unit... should look nice in your HHR!
Originally Posted by adamlowery
Probably not worth more than 5 or 10 bucks. I'll be a good man and give you 20 for it.....you pay for shipping.lol
It would be nice just to find a use for it since it's just taking up space out in my garage. (heck, I keep forgetting it's out there)
LOL is right... the shipping would cost more than the box is worth.
(one BIG heavy mutha)
Hey Jaydogg-could you post a few pictures of how you ran the wires? Did you need to make a hole coming out of the spare tire compartment?
I retire Friday then can devote some time into my baby (HHR, not my actual kids).
i will take some pics today once it is done. like most have said this is the easiest car i have worked on. once you get the rcas to the back there is a little tunnel under the cubby holes that they can pass threw. i was shocked when i found this out. if im not mistaken this tunnel is between both of them. i started feeling around on it until i found the hole, then when my fingers touched from both side i knew i had it.
Originally Posted by snova031
A 10" can extend as low as a 15" will.
A 15" can be just as tight as a 10" can be.
It's all about alignment...box, power, tuning, etc.
P.S.- may want to look into the CVX's...will work just as well as L7's and don't require as large of an enclosure as the L7's do
Originally Posted by jaydogg
i have three 10's in my cavi and the just dont get low enough for me, this box was built for these 3 10's by mtx and im running 900 watts rms to them, they rate at 750-1000 rms so im on the high side. as for 15's we built several box at the shop i used to work for and they just never seemed to hit the double bass drum like 12's or 10's. it might just be me but i know that 12's do everything i ask them to do.
Awesome read
i would also change out the head unit, im not the biggest fans of rca converters, if you dont have the premium head unit. for one the inside will sound 1000 times better than the stock headunit, and if you get a headunit that has 3 rca's, front, rear, and sub, some of them allow you to control the subs volume, as in you can turn them off or go full tilt with them. of course this is after you tuned the amp. for example alpine has a sub menu to where you can mute them or you can go 1-15 on them, sometime you dont feel like alot of bass or sometimes you want all the bass you can get. or heaven forbid you guys have cops like we do that will give out tickets if you are to loud. this feature has saved me plenty of times witht these tickets because i muted my subs and when they said i was to loud i said what do you mean and turned the stereo up with no sub, there was no bass, no ticket.
Agreed!!!
line out converters sound like ass
