new rear floor installation
Old Aug 17, 2006 | 09:33 PM
fallenSaint's Avatar
That looks very nice and clean, also like the use of the factory sub location so it doesnt look out of place.
Old Aug 17, 2006 | 09:47 PM
TX-HHR's Avatar
Joe,
That looks great! Very clean look.
Old Aug 18, 2006 | 04:51 AM
JOEK86's Avatar
Originally Posted by ng8650
Joe your system looks awesome! I like what they did to the old OEM sub area. I plan on doing something similar later on. I like that trim piece they put on but I can't do that on my setup cause the sub box is in the way...
I also need to make my spare easier to get to, just in case. I have plans for that later...
Is there only one amp running all the speakers? Or is it pushing the sub solo? What are you running for the head unit?
NG
I only have one amp it is an Audison LRx 6.9 6 channel 70 watts to each speaker set @4ohm and about 480 to the sub. I have an Eclipse CD7000 HU.
Old Aug 18, 2006 | 08:11 AM
ng8650's Avatar
Thanx...
Old Aug 18, 2006 | 09:23 AM
Harpozep's Avatar
Nice looking rig Joe What exactly is in the rear sub spot? It looks like the sub amp. I'm sure it sounds great. Maybe I should go with one down firing 10 as well?
We are doing a stealth version in our HHR. Amps under the seats, and a new panel such as yours with two tens firing up in the rear compartment area close to where your amp is located. I want the subs closer to the rear seat so more of the cargo area floor is open to having stuff put on it without interfering with the sound.
Then the rear cargo mat is getting cut so the area under the subs can be covered or uncovered while the rest has the rug. We use the car as a family vehicle so utility first in out case. I'd love to do a showy one, but not in our current car. Last week I had a bunch of 5 gallon water bottles, this week Katy's bike and the stock muffler are back there. I just put on the Imco and while I'm deciding whether to keep it or not, the old stock muffler rides in the cargo area.
THanks for the pictures. eep on modding
Old Aug 18, 2006 | 09:50 AM
JOEK86's Avatar
My Audiocontrol DQXS equalizer/crossover is mounted in place of the stock sub.
Old Aug 19, 2006 | 12:38 AM
Navyflyer11's Avatar
very nice! very clean.
Old Sep 2, 2006 | 09:18 PM
rdcoffe's Avatar
Where did you put spare. Your set up is awesome, but do you have any pics of under the sub, so we can see how you kept your spare.
thanks
Old Sep 3, 2006 | 05:54 AM
JOEK86's Avatar
thanks
The spare is still under there.......matter of fact there is a little fold down leg that holds everything up in the event of a flat. That way there is no disconnecting of the sub or amps, and you are not trying to hold everything up while you remove the spare and tools.
I don't have any pics of this, but the next time I get in there I will snap and post.
Joe
Old Sep 3, 2006 | 10:43 AM
rdcoffe's Avatar
thanks. I am building a similar box and was wondering how you did it. If you can get some pics it would be great. Is your box all MDF or is it fiberglass and MDF
