No FM
FM gets one channel nothing else comes is AM works, CD works
Welcome to the site, perhaps the antenna is damaged or the radio itself is not functioning.
Is the front antenna in place?
Could be the antenna's amplifier. |
Is this a new thing? Did it start after a new radio was installed? You got to give us something other than "it doesn't work".
The FM gets one channel, indicative of antenna problem
the AM works and the CD player works , here are some threads regarding the antenna https://www.google.ca/search?q=hhr+a...iw=375&bih=626 |
Originally Posted by Oldblue
(Post 895441)
I would think AM would have a reception problem more than FM if the antenna had a problem. Please explain. |
FM will pick up closest signal, if the antenna ground or amp power wire is corroded .
AM is a stronger signal. My antenna was damaged and water got into it, I replaced the screw in antenna mast and the fixed my problem I could get one local FM station with the damaged antenna. https://cimg2.ibsrv.net/gimg/www.che...b828a781b.jpeg Part number 1 was my issue , the connector above the headliner in cable part #7 could be the problem Or the connector at part # 6 |
OK thanks
