No FM
Old Jun 15, 2020 | 01:15 PM
Tamara Stringer's Avatar
No FM
FM gets one channel nothing else comes is AM works, CD works
Old Jun 15, 2020 | 03:03 PM
Welcome to the site, perhaps the antenna is damaged or the radio itself is not functioning.
Old Jun 15, 2020 | 03:18 PM
Is the front antenna in place?
Could be the antenna's amplifier.
Old Jun 15, 2020 | 10:00 PM
Is this a new thing? Did it start after a new radio was installed? You got to give us something other than "it doesn't work".
Old Jun 16, 2020 | 07:48 AM
The FM gets one channel, indicative of antenna problem
the AM works and the CD player works , here are some threads regarding the antenna
https://www.google.ca/search?q=hhr+a...iw=375&bih=626
Old Jun 16, 2020 | 01:09 PM
Cat Man HHR's Avatar
Don't understand how the FM only has one channel if the antenna is bad.
I would think AM would have a reception problem more than FM if the antenna had a problem.
Please explain.
Old Jun 16, 2020 | 01:16 PM
FM will pick up closest signal, if the antenna ground or amp power wire is corroded .
AM is a stronger signal.
My antenna was damaged and water got into it, I replaced the screw in antenna mast and the fixed my problem I could get one local FM station with the damaged antenna.
Part number 1 was my issue , the connector above the headliner in cable part #7 could be the problem Or the connector at part # 6
Old Jun 17, 2020 | 02:39 PM
OK thanks
SwaintaN
Dec 26, 2021 10:12 AM
yellowjacket
Sep 15, 2017 06:42 PM
herbk98
Mar 10, 2014 10:28 AM
adamlowery
Apr 11, 2012 07:43 AM
mudbilly
Jan 7, 2012 10:09 PM
