Optima battery question
Old Sep 5, 2008 | 02:37 PM
Lee3333's Avatar
Can you use a regular charger on an Optima battery?
Old Sep 5, 2008 | 02:48 PM
masterchief1112's Avatar
i would assume it would depend on the type of battery it is. i would say wait till someone more knowledgeable on this subject answers.
Old Sep 5, 2008 | 03:14 PM
Ed RazorLite's Avatar
Which model Optima?
For any AGM battery you should not use a basic charger unless you are only charging it up for a few minutes.
The reason is that most standard battery chargers output a set voltage of maybe 15-16v.
After a few minutes this can heat up the plates of an AGM battery.
A proper AGM battery charger will sense battery voltage and if it is really low it will output 15-16v for a few minutes until its near full, then voltage will lower to 13v or so and give a "soft charge" to the battery which is much safer.
Old Sep 5, 2008 | 09:57 PM
flyhhr's Avatar
you need to put it on a trickle charge like a 2 amp setting you will be fine
Old Sep 6, 2008 | 12:10 PM
Lee3333's Avatar
Then would a trickle charge on it be alright? This is not for my HHR-my dealer finally realized that I was not wrong, and the radio I installed was not causing my battery to die only when the temperature was cold.
I need a battery for my project hotrod-a Jeep I am putting a small block Chevy into. But, until I get the new motor in, the 6 cylinder is hard to start so it may kill the battery. I know that my current battery is also bad, since I disconnected both pos and neg, and it was stone dead after a couple of weeks.
Old Sep 6, 2008 | 06:00 PM
collyn's Avatar
Yes
Old Sep 6, 2008 | 06:40 PM
Lee3333's Avatar
Then I shall get one. I have to find out the correct size for me-physically to fit in the Jeep, and performance wise to crank a 450 SB.
Next question-what is the difference between the yellow, red, and blue top?
Old Sep 7, 2008 | 10:19 AM
collyn's Avatar
They red is primarily a starting batt, yellow is a deep cycle batt, the blue is like a yellow in function, but extreme vibration resistant and marine certified for boats. All will work in your jeep. I'd just get a yellow if it were me. slightly less cranking amps than a red, but more forgiving if you repeatedly drain it down and recharge it.
Old Sep 7, 2008 | 11:10 PM
flyhhr's Avatar
You can put the battery anywhere in the car if you want. But most of them would be a 75/35 d battery. I am using 2 yellow tops in my hhr. But I do have 6 that will be going in when ever I get my money straight to get my system installed. I have 6 10'' 9 amps and 6 set's of comp. What I am using them for now is my air bag's, tv, playstation strobes, neons,gps,camera. What year is the motor you are putting in. The Gm alternator for as long as I know have a bad voltage reg. in side them. I would get a hi out put alternator with a battery cut off switch that should help you out just my 2 cents
Old Sep 8, 2008 | 04:56 AM
mistermike's Avatar
I have a Vector battery charger that is superb and has a special setting for AGM batteries. They have been taken over by Black and Decker, but the charger line up appears to be identical.
