Parking light wire diagram
Old Jan 30, 2021 | 11:44 PM
The BRN wires go to the parking/marker lights/tail lights. They are the only wires connected to the relay. All of the other connections are in the fuse box.
Old Jan 31, 2021 | 10:41 AM
Bonez's Avatar
How does one sinply whack his shins on the running boards of an HHR ? Im trying to fathom this theory.....
Old Jan 31, 2021 | 11:11 AM
C'mon, he said don't ask!!
Old Jan 31, 2021 | 12:06 PM
mrmarkuSS's Avatar
Thanks donbrew,that helps.
What I can't figure out,if any of the parking lamp wires (BRN) were causing a short,it would blow the fuse for the low beam,or at worst,cause the offending wire to melt its insulation and possibly start a fire (YIKES). I even tried a new headlamp switch,it did not solve the problem. I swapped relays,still kept blowing the fuse.So,what could be causing the fuse to keep blowing?
The way I bypassed the parking lamp relay hasn't caused the fuse to blow so I still also have the interior lights associated with it (steering wheel buttons,HVAC knobs,tiny light in ceiling to illuminate window switches)
The diagram shows a white/red wire,where does that go to?
Old Jan 31, 2021 | 12:26 PM
I thought I included the wht/red; sorry. It goes to the BCM that supplies a ground signal. It's possible there is an internal short.
Old Feb 1, 2021 | 02:11 AM
mrmarkuSS's Avatar
Thanks again donbrew, You gave me more info to work with,and why do I get the feeling the issue is most likely the BCM? I read up a few posts regarding the BCM and noticed some similar issues as to what I am experiencing.
I wish I could just bypass the relay permanently and wire it to low beam/hi beam. But no,this was the work of some GM crackpot engineer overthinking a simple operation.
goetylsd
18
Jul 24, 2010 03:20 PM
solman98
Jan 1, 2009 06:50 PM
Leon
"How To" Tutorial Library
Jul 31, 2008 11:43 AM
steelwoolghandi
11
Mar 21, 2008 05:02 PM
giant96
Mods - Exterior
Jul 17, 2006 12:14 PM
