Which is power antenna lead?
if I pull the panel where the right tweeter is, which wire is the power to the am/fm antenna?
thank you. |
Since you didn't state a year or model, I'll take a generic shot.
The pink wire. |
Yep pink wire!
Originally Posted by Oldblue
(Post 830284)
Yep pink wire!
Your amplifier may be bad. Here is a thread for you. https://www.chevyhhr.net/forums/prob...problem-38716/
(Post 830291)
Not that amp, the antenna amp, did you even look at the thread I linked?
| All times are GMT -5. The time now is 05:09 AM. |
