Radio controls on steering wheel
Old May 23, 2011 | 06:17 PM
Originally Posted by Ward
Has anyone added the controls to their steering wheel? I have the three gm part numbers for the changeover. Is it necessary to remove one battery cable for a safe install? The 3 parts cost about 75 dollars.
Thanks
Short answer: not necessary, but probably best. I have removed the airbag assembly a few times, and am still living.
Old May 23, 2011 | 06:27 PM
Not sure why guys want to risk airbag deploy just so they don't have to disconnect the battery. Is it so hard to pull the cable? Or they just like seeing the inside of an ER from a gurney?
Old May 23, 2011 | 07:53 PM
GTOMIKE's Avatar
As long as you are not in drive doing this mod you will be fine with the battery connected.
Old May 23, 2011 | 09:27 PM
foolmoon_design's Avatar
wouldn't it be easier to just pull the fuses?
Old May 24, 2011 | 02:52 PM
Ward's Avatar
Originally Posted by jbman
Well I ordered the parts sure hope they will be the right ones. Switch # 25862239 Cover # 25812392 {hope its silver} Harness # 25816515 ordered from: GMPartsDirect.com cost 76.24 supposed to fit my 09 HHR 1LT
Let us know how this all ends.
Thanks
Old May 25, 2011 | 11:24 AM
prod's Avatar
Note, if you are only swapping the controls, you dont need to disconnect the airbag at all, just pop it out and let it hang down.
If you are removing the wheel entirely, you do need to disconnect the wires. I just removed the plug from the harness. I dont see how this could set them off, its not like unplugging the bag will introduce any kind of activation signal, theres no motion sensor in the bag itself. It gets signal to deploy from the airbag controller which I think is mounted under the shifter console.
Old May 25, 2011 | 12:17 PM
sincfiles's Avatar
Originally Posted by GTOMIKE
Go here put in $80.00 in the best offer and they should take it can`t beat a complete leather wheel setup with free shipping and save the extra work.
http://cgi.ebay.com/ebaymotors/Chevr...66827571877419
Will this wheel actually plug and play in a 2008 LT1 ??
Thanks
Old May 25, 2011 | 04:59 PM
GTOMIKE's Avatar
Yes it will
Old May 26, 2011 | 10:33 AM
sincfiles's Avatar
Yes it will
Thanks GTO, I may have to purchase this steering wheel.
Old Jun 13, 2011 | 10:54 AM
jbman's Avatar
Mine works now, wish it would go throught the stations rather than just the pre selected ones, it does change cd tracks too.
