Radio doesn't work
Old Feb 3, 2013 | 11:01 PM
phbassnotbass's Avatar
Angry Radio doesn't work
How do I remove the radio
Old Feb 4, 2013 | 12:33 AM
B.Diggity's Avatar
Grab the panel that's around it by the air ducts. Pull gently hard... lol itll pop out n there she is.
Old Feb 4, 2013 | 02:49 PM
Thanks, I thought so bugt it seemed to rasy
Old Feb 4, 2013 | 04:08 PM
db/sb's Avatar
Wait.......ah, what??
Old Feb 4, 2013 | 06:54 PM
B.Diggity's Avatar
Lol yea its pretty easy but a huge pain to put back in.. took me like 10 min two folks smh
Old Aug 12, 2013 | 07:56 PM
I fixed it
I finally got around to fixing my burnt out high beam on my headlight when the low beam quit to. My radio started working again. Whoda thunkit
Old Sep 28, 2021 | 07:52 PM
Triggrsolo's Avatar
My 2009 hhr stopped working after my battery died with my list in ignition turned on accessory. The anti lock kicked on. I got a jump, the car started but radio wont turn on. So fuses are good, everything works fine just not radio
Old Sep 28, 2021 | 08:59 PM
How were the cables attached? Did you follow the directions in the Owner Manual?
Try a battery lobotomy, disconnect the negative battery terminal only, for a full 30 minutes, then reconnect the cable. That should reset the computers .
desertrat
Sep 9, 2019 05:52 PM
Aholland06
May 18, 2013 03:14 AM
Jobouche
Jun 29, 2011 04:16 AM
mcgaugh
Nov 16, 2010 08:10 PM
hzl6cm
Jun 1, 2010 06:23 AM
