Running Powerwire From Battery to Amp
Old Jul 22, 2006 | 11:29 AM
JoshManHHR's Avatar
Are there any how-to guides on wiring an Amp's power cable from the battery to the Amp in the trunk for an HHR? Where is the best place to run the wire through the hood into the car? Maybe someone can post some pics of where they have thier power wires running.
Thanks!
JoshMan HHR
Old Jul 22, 2006 | 11:55 AM
captain howdy's Avatar
You battery is in your trunk. It's a real short run so you don't need a how to.
Old Jul 22, 2006 | 12:01 PM
JoshManHHR's Avatar
Yes it is! Just found out myself. Please disregard this post.... It is amazing how this car is put together! The head unit is so easy to replace, and now I see it is prob the easiest car to hook up and amp to. Amazing! Thank you HHR!
Old Jul 22, 2006 | 12:02 PM
XTRMEASURES's Avatar
yea what Cap said should be real easy
Old Jul 24, 2006 | 10:21 AM
ng8650's Avatar
I don't know about you, but I had to hacksaw the back of the stereo slot to make my RCA cables fit. I got the Alpine 9856 in last night and the three RCA cables wouldn't allow the stereo to go all the way in.
I had to cut the back until it fit all the way in. The OEM stereo is easy to remove but there is not a whole lot of room back there. MY 9856 is touching the back panel area. I know someone else mentioned having to modify the back panel to make there stereo fit...
Ng
Old Jul 24, 2006 | 10:22 AM
DaJoker's Avatar
Yep, had to do a little modification myself when I put my Kenwood DPX-701 in as well. There just isn't much room back there.
Old Jul 24, 2006 | 10:59 AM
jaydogg's Avatar
Ng
that was me. i have the 9855, and i just used a dremel to do the cutting. mad it real quick and easy.
Old Jul 24, 2006 | 11:03 AM
ng8650's Avatar
I was considering the dremel but was worried about the harness back there. I used a hacksaw blade and it worked pretty good.
Ng
Old Jul 24, 2006 | 02:34 PM
jaydogg's Avatar
Ng
it cut throught it like a hot knife through warm butter
Old Jul 24, 2006 | 03:01 PM
DaJoker's Avatar
so does the hacksaw blade
