??s about shu and new speakers
Old Jun 18, 2008 | 07:18 PM
mudd274's Avatar
Would you gain anything by replacing the 4 door speakers?
I would like alittle more volume than what Im getting without replacing the factory head unit. I dont care about all the thump and such.
any suggestions
Old Jun 18, 2008 | 09:04 PM
tim_tenn's Avatar
I did some checking on this myself, and all the audio installers I have talked say the same thing: yes, you will notice improvement in overall sound clarity and quality with better speakers -- how much improvement depends on the speakers installed. Of course, replacing just the speakers is not as good as installing a new, higher-end system. But I am sticking with my factory unit, and will be installing new speakers shortly. I replaced the speakers in my '03 Impala and noticed better overall response to both the highs and the lows.
Old Jun 18, 2008 | 09:38 PM
tooter1's Avatar
I upgraded to the higher end stock unit and it was a 100% improvement in sound.
I have recently started to upgrade speakers and have tried some Polk db651 & db651s and couldn't get the low end sound like the stock speakers.
So then I exchanged them for some Alpine SPS-17C2 and got a little more low end but not much more, so now I'm going to try some Kicker 07DS600's and see if I like them.
If I don't I know I'll have to put in a totally new setup, but would like to keep the stock headunit.
I will probably go ahead and do a 4 channel and a mono amp setup. Along with new door speakers.
Old Jun 18, 2008 | 09:42 PM
Rcflyboy's Avatar
I just ordered new door speakers from Crutchfield and they suggested getting speakers with a high sensitivity like 92 to 94 db. They also suggested getting 2 ohm impedance. I ordered Infinity reference 6022i at there suggestion. $99 a pair.
Old Jun 19, 2008 | 05:01 PM
mudd274's Avatar
let us know when you try them please
Old Jun 19, 2008 | 07:40 PM
Rcflyboy's Avatar
I received the speakers yesterday. Hope to get them in this weekend. I will let you know how they sound.
Old Jun 27, 2008 | 08:08 PM
tooter1's Avatar
^^Did you get the Infinity speakers in?
Old Jun 27, 2008 | 09:30 PM
Rcflyboy's Avatar
Yes I was able to install them the other day. I also installed baffles behind them, Crutchfield said they would slightly increase the bass. (not to mention keeping them dry.) Yes they did make the sound better, especially the mid bass and high's. However the volume had to be turned up pretty high to get that. I would say it was worth about a 35% to 40% improvement over the stock speakers. The improvement would have been greater except the stock head unit just doesn't put out much power. I would guess maybe 3 or 4 watts per channel.
Old Jun 27, 2008 | 09:39 PM
Rcflyboy's Avatar
Tonight I installed a Pioneer DEH-P6000ub head unit. I bought this at the same time as the speakers. I just wanted to see what a difference the head unit would make with good quality speakers over the stock one. WOW!!!! what a difference it was. The improvement had to be over 100%. The 14 watts per channel really shows. Not to mention all the adjustments I could make. The bass and mid bass was the most noticeable. My advice after this experiment is the speakers help a good bit but the head unit is the big difference.
Old Jul 2, 2008 | 09:46 PM
mudd274's Avatar
Thanks for posting. I really didnt want to change the shu but knew if I wanted alittle more volume it would need to be changed. I just fear the rattles that might start by removing the waterfall and such to replace hu and speakers.
thanks again.
