Shnog goes Boom
Old May 9, 2006 | 08:33 AM
  #41
ng8650's Avatar
I'm going to buy Infinity Reference series speakers and amps, I like their quality and they fit my budget. The amp I want is their 600 watt 6 channel (I'll be using it in 5 channel mode), but I'm not sure I'll be able to fit it under the adjustable shelf area. If the 6 channel doesn't fit, I'm going with their 4channel which is rated at 111RMS x 4 (front component and rear 6.5 speakers) and there 2 channel (bridged, powering the sub) that is rated at 270+RMS x 1.
NG
Old May 9, 2006 | 07:59 PM
  #42
snova031's Avatar
Originally Posted by Tokyo
Your vehicle's electrical system charges a cap... A stiffener works on the premise that they store power during intervals when it is not required, which is most of the time, and release it when momentary peak demand exceeds what is available from the car's power system. Along with an adequate basic power supply, a stiffening capacitor for your amp is the simplest way to be sure your system always gets every bit of current it needs.
Problem is, most caps are horribly inefficient, and most of that 'energy' stored is wasted in heat...look at the ESR values of most caps (most of them don't even publish this number). Also, on top of that, power is always pulled by the highest source of voltage. The only time a cap will be used in a system is when both the alternator and battery are tapped for voltage...which means the cap is adding a load onto the alternator, making one more load that has to be charged.
Here are some graphs that were the results of tests done by Richard Clark and David Navone..
http://www.davidnavone.com/richardcl...mp%20dummy.jpg
http://www.davidnavone.com/richardclark/CLEWIS~1.jpg
Old May 11, 2006 | 09:01 PM
  #43
ng8650's Avatar
Calling all Audio Gurus...
Okay lets say you have some door speakers that are rated at 60W RMS. You've narrowed your search to two amps. One is rated at 70W RMS and the other is at 40W RMS. Which one do you pick?
Do you want to go over or under your speaker's rated RMS? If you do go over, are you going to blow your speakers?
Ng
Old May 11, 2006 | 09:05 PM
  #44
Tokyo's Avatar
70W...
Clipping is evil... Underpowered amps deliver clipping more often than Domino's delivers pizzas. (Of course, there's more detail to it than that, let the arguuments begin). One is more likely to destroy a driver with clipping than too much power.
Old May 11, 2006 | 09:06 PM
  #45
captain howdy's Avatar
The 70 watt one. It's better to over power your speakers rather than under power them.
Old May 11, 2006 | 09:13 PM
  #46
ng8650's Avatar
Thanx for the quick responses Edo (Tokyo's former name, I'm a History Major) and Howdy. I'm assuming the same rule applies to subs? right?
Ng
Old May 11, 2006 | 09:26 PM
  #47
Tokyo's Avatar
Yeah, Meiji decided (after the Shogunate), to rename Edo to Tokyo, to signify Japan's status as powerful Eastern capital city. However, do you know who established Edo as the governmental center of Japan (of course, excluding the Emporer's palace in Kyoto)? (Jeopardy theme plays in the background)..
Of course, I'm not 138 years old, so Edo doesn't really work for me... lol
The RMS ratings we discussed most definately apply to subs. Have you narrowed down a bit more what you're looking to have installed?
Old May 11, 2006 | 09:35 PM
  #48
ng8650's Avatar
Ah young Tokyo...I see you are educated in the Asian studies...What is....Tokugawa?
As far as my setup, I've already started buying the speakers, they will all be infiniti reference components and the sub, if I can fit it, will be a 10" perfect series. The amps I'm undecided. I need to head to my local best buy with measuring tape and find out what fits underneath the adjustable shelf in the back. I've been researching the Alpine "V" amps and that's were I got the 40w & 70w RMS numbers (4 channel).
What about that possible custom sub enclosure you were thinking about?
Ng
Old May 11, 2006 | 09:45 PM
  #49
Tokyo's Avatar
Ah... Nice one! It was Tokugawa! As a Vietnamese-Irish American born in Korea, and having served in Japan for about 10 years, I had to brush up on my studies! Omedeto!
It turns out the bins forward of the parcel tray are useless for the project we spoke of earlier. They're just a bit too slim to provide space for a sub, though for 6.5" pods they'd work nicely. And behind the panel, in the stock location for the Pioneer pod, is also a no-no... A sub is going to need more airspace than that area has to offer, it looks like it's pre-fab time for 'ya, bud!
Old May 11, 2006 | 09:50 PM
  #50
ng8650's Avatar
Well it looks like the adjustable shelf is going on the top slots...Fabricate huh....Watch ya got! And how much for shipping to SoCal?
Ng
