Single LED light
Old Feb 17, 2006 | 09:57 AM
BIGJP's Avatar
Single LED light
I have mounted a Varad LED light and used the IGN harness (yellow wire) and hooked the constant 12V to the positive post on the fuse box, and grounded on the strut tower bolt. Simple enough but when I try to remote start the stock alarm activates and the horn blows then the car shuts itself off. Also there is a nasty click when Ignition is turned off. Can anyone help me??
Thanks
No its just a single LED for theft deterrent.
Old Feb 17, 2006 | 10:10 AM
captain howdy's Avatar
Like a single LED or a strip?
Old Feb 17, 2006 | 10:18 AM
Skatetheglobe's Avatar
If you used the ignition harness its the brown wire.I asked yesterday and hooked up my remote wire for my amp with no problems.
Old Feb 17, 2006 | 10:36 AM
adamlowery's Avatar
Where did u mount it and what is it for
Old Feb 17, 2006 | 10:45 AM
BIGJP's Avatar
Would the brown wire be used as a ignition grounded when engine is off?
Old Feb 17, 2006 | 10:46 AM
BIGJP's Avatar
Old Feb 17, 2006 | 10:51 AM
You used a capacitor right?
Old Feb 17, 2006 | 11:06 AM
The brown is the acc power and you ground somewhere to the body.
Old Feb 17, 2006 | 12:28 PM
BIGJP's Avatar
What kind of capacitor??
Old Feb 17, 2006 | 12:37 PM
I was lead to believe if you are hooking up a singe led you are supposed to hook a capacitor up to the one line and a resistor up to the other line but I could be wrong. I have never personally installed LED lights in any of my rides and everyone else I know that has lights on their rides use neon.
