Speaker change help
Old May 23, 2008 | 12:04 PM
stuns's Avatar
Question Speaker change help
Ok just ordered two sets of Kappas for the car a few days ago, ann they should be arriving sometime soon. What should I make sure I have on hand harness/adapter wise for the switch?
By the way for right now they are going to be powered of the factory Pioneer amp. Eventualy I will be able to finish the rest of the system with a 4ch amp for the kappas and a mono amp for my 12incher.
Old May 23, 2008 | 12:07 PM
shaginwgn's Avatar
speaker wire would be good, that should be all you need because have the premium sound system you don't need the speaker rings/mounts. The premium already has them door panel trim remover tool would also be a good idea and investment.
Old May 23, 2008 | 12:23 PM
Ed RazorLite's Avatar
Sound deadener in the door is always good.
www.secondskinaudio.com
Old May 23, 2008 | 07:21 PM
stuns's Avatar
Thanks I have the panel remover already. The dynamat will go in when the new amps are installed.
Old Jun 6, 2008 | 03:55 PM
stuns's Avatar
They are here. Now just need to put them in.
Old Jun 16, 2008 | 05:33 PM
knightRS32's Avatar
I'm being lazy here, but are the rear speakers 6x9s?
Old Jun 16, 2008 | 09:36 PM
mudd274's Avatar
no 6x9s
Old Jun 17, 2008 | 09:24 AM
stuns's Avatar
6.5's
Old Jun 17, 2008 | 10:22 AM
collyn's Avatar
LF +tan-grey
RF +LtGreen-DarkGreen
LR +Brown-Yellow
RR +DarkBlue-LtBlue
Speaker wire from the factory is long enough and more than suffecient for anything less than 250 watts per speaker.
Dynamat Xtreme is a good investment...especially for low power(stock) systems as it will make the noise floor lower and make the less effecient Kappas play to their abilities. You don't need a panel tool on HHR's....simplt remove the screws and start yanking from the front inside corner of the panel. The clips will come off easily.
Old Jun 17, 2008 | 01:43 PM
stuns's Avatar
"less effecient Kappas"? Explain please.
