Stereo/Speaker Issues
I hate to add to the long list of speaker questions but after a long search, I have not found my exact story. I apologize if this has been asked and answered. I also apologize that I am a total novice at these things.
I have a 2009 Chevy HHR with the cheaper stereo system. One-by-one, I started losing the door speakers. I'm not sure of the exact order but am down to the rear left. Assuming, from what I've read here, that the stereo is likely not the culprit, I put new speakers on my Christmas list and received them. I had recently pulled the front driver door panel and broke some clips (which I've got replacements for) so I started there this morning. I pulled the speaker housing and ran alligator clips from the solder on the old speaker to the new speaker and I am getting nothing. I clipped into the harness as well as I could and still got nothing. I ensured that the tan is going to the positive. My thoughts are that the harness to the back of the speaker may be corroded from water based on what I've read on other threads here but want to get advice before I start tearing apart the stock wiring. Another thought is that the wires may fail as the doors are opened and closed. How should I troubleshoot this issue? Any other advice? I am considering a Crutchfield replacement for the stereo regardless but that wouldn't help if the wiring is bad. I am not against running new wire either way. |
This is the best pic I could find. The harness plugs in on both ends, I think.
https://cimg7.ibsrv.net/gimg/www.che...f58b28d0d0.png |
That harness looks clean, dry and free from corrosion. Without taking the door off, I've got no way to look further. Is there something I should be looking for there?
Something I didn't think of before: I can open the other windows from the driver door but cannot close them. The locks operate normally from both doors. |
Originally Posted by vogtrj
(Post 858261)
You could contact Crutchfield, and simply run new speaker wires |
Originally Posted by Doc brown
(Post 858270)
I'm not sure what you mean by "clipped into the harness as well"? If you lost one speaker at a time, the problem may be as simple as the rust on the old speakers themselves. The new speakers probably came with speaker wire and connectors. Don't be afraid to cut the old wires about 3 inches or so from the clips, and splice the new wire into the old. Then test the new speaker. If it works, then untwist the splice, slide on shrink tubing, re-twist the connections then solder them, then shrink the tubing about the newly soldered connections.
Could use a cheap VOM to test continuity of the wires.
(Post 858270)
Thank you all for you contributions to my solution. |
Thanks for posting back your solution. Glad to hear it's all working! :thumb:
And now, time to Crank It UP!!! |
