stock amp
stock amp help help help
i searched and i cant find it but im pretty sure i saw it some where but i have a 2lt and have the 7 speaker system and are all the speakers and the sub running off the amp and if i bypass the amp will i be able to tap int the wires like a remote and the speaker level conections for a converter for rca jacks thanks for any info
Last edited by cjnappo; Feb 10, 2006 at 12:50 AM. Reason: need people to read and help
I've posted the schematics of the radio and amp wiring here:
http://n8zcc.com/pics/HHR/Radio.gif
http://n8zcc.com/pics/HHR/Audio_Amp.gif
https://www.chevyhhr.net/forums/audio-video-17/direct-wiring-2006-hhr-7-speaker-system-amp-740/
I'm getting ready to install a CarPuter in my 2LT and wire it up to the stock amp, will post pictures and progress soon.
okay
well i want to install a new sub and mono block amp for the sub and i want to tap into the unamplified audio signal for a line conversion (rca jacks) and also use the remote that turns the amp on to turn on the new amp will i still be able to use the factory amp for the other speakers together with the new amp and do what i want
What more help do you need? You have the wiring diagrams.
Here is more help for you, this is a picture of all the audio connectors and the pinouts, I don't know what else we (as in this board) can do for you.
http://n8zcc.com/pics/HHR/Audio_Connectors.pdf
you know what
im sorry that im not so intelligent as you folk are but you dont have to be rude i cant beleive you guys even have any friends im not a fuking audio person i run a resturant and im sorry if i need things to be explained to me thanks for the hyrogliffiks and i think ill ask someone else
You really have everything you need.
help help help,
Somebody is a little touchy and needs a hug.
Do you want someone to walk you through step by step or something?
