sub enclosures
sub enclosures
does anybody know where we can get sub enclosures other than the factory one that will go in side the quarter panels i would like to put my 10's in both quarters .... can anyone help ?????????
It's not very expensive either (if you go to a good shop!).
The most important thing is that they use a thick front baffle board.
Check into it...
does anybody know if the shape of an enclosure has anything to do with sound?The box I'm going to build will be odd shaped so I want to make sure it will sound good.Aslong as I have the correct air space I should be ok right?
Did anyone post in the forum the actual dimensions of the stock sub enclosure box? (HeightxWidthxDepth) (Or failing that, just the depth?) And does anyone have an opinion on the speakers that say their 'optimized' for small enclosures?
