Upgraded factory ground location?
So I'm sure some of you have noticed that the factory ground is on its own little built out tab which I can only assume is not as good as just grounding to another panel or the frame.
I'm also getting some odd feedback noise (not alt whine) which I figure might be caused by grounding the amp to the battery and/or the factory ground location being less than ideal.
Curious to know if anyone has modified their factory ground. I did sand the metal at that spot and added a copper lug to it but I'm not sure if that really helped much. Overall my stereo system runs great otherwise. But would like to combat the odd feedback.
It is attached to all of the metal in the frame and body by welds and bolts; that makes for a prodigious bus. Why in he world do you think the attachment point of a 6 or 8 gauge wire would make a difference?
I would look at device grounds not the battery ground if I was suspecting such a thing.
so would you suggest grounding the amps to the chassis instead of the battery? I've also got a second battery hooked up. Would it be better to ground that to the chassis as well instead of directly to the main battery?
Sub amp does great. I dont think its a ground quality issue. But I've read that all grounds should be to the chassis.
Thank you, I will be switching some grounds up today! I need to add a fuse between batteries as well.
You do know that the chassis is ground and the battery negative post is grounded to it; to make it work; not the other way around. Ions flowing and all that.
Floating ground works for most thing until; you get to digital stuff.
uhh what is floating ground? Did I hook it up wrong? I have everything on chassis ground now.
