USB intermittent, multiple flashdrives
Aloha all,
Had my HHR for a couple of years now, 2010 with the pioneer package and subwoofer (no GPS nav).
I've tried multiple USB drives with the stereo and they all tend to stop working, very intermittently, but for days at a time. I have used a Corsair and a Sandisk so far and they both just stop working.
I did a search and the last page of this thread seems to detail a similar scenario, but no responses. Resolution seemed to be that the guy just gave up on the unit: https://www.chevyhhr.net/forums/audi...g-29434/page3/
I have come to the conclusion that the USB port is not passing power through it at all during its downtimes. The way I tested this was to use a 3rd flashdrive that had a red indicator light, which did not turn on, and to use a low-amp cellphone charging/data cable, and that didn't provide power to my phone. I've tested both of these when the USB is working properly and the USB drive's red light turns on, and the phone detects a "slow" charge(which is fine, that's just because of the low amp cable).
Any thoughts? Fuses, loose connections, etc?
Thanks in advance.
Thanks in advance.
I don't think the USB is supposed to supply power, if it does it is most likely .5 amp or less. The cable does not limit the power, it is rated to carry that much before failure (catastrophic). Some cables don't even have the power wires, data only.
Older USB devices can only handle a max of 8-16 Gib, some even less. When the book was written there may have been only 8 Gib available so they don't mention limits. 6 years ago a 8 Gib USB 1.0 drive cost $20-30.
USB technology changes very quickly we are on something beyond version 3.0 now, and moving on to newer technology.
The contacts on the USB port can get dirty. The plastic can get cracked and cause the contacts to be flakey.
A friend of mine has to buy new charger cables on a weekly basis because the mini end suddenly won't plug all the way in.
Will the drives work in other devices? Is it the drive or the device?
I would probably blame cheap electronic components being mistreated over time and failing. Probably cheapest to get a new head unit.
Cables have a maximum power rating and are unable to exceed it- for instance, a fast charger is 1.1 amps, while a typical dollar store or bargain cable will not exceed .5 amps. I encourage you to experiment with odd cables and your phone's fast charger to see it firsthand if this is still a topic for debate. And true, micro usb cables can be purely power, but they cannot be purely data. It goes against the nature of what a USB port is.
They can, however, be incompatible or too low amperage to supply enough power to register that a phone is charging, which is why I included that variable in my original post:
" I've tested both of these when the USB is working properly and the USB drive's red light turns on, and the phone detects a "slow" charge(which is fine, that's just because of the low amp cable)."
My flash drives have had their contacts cleaned, no cracks are present, they work in all other devices that I own (2 laptops, 1 desktop).
Any thoughts?
Exactly how does a wire limit current through it. By melting, unless there is a circuit in the connector. The amount of current memory or LEDs require is tiny. My Raspberry Pi 1 runs on 1.2 amps and will handle at least 2 small USB powered devices like a wifi adapter and a thumb drive or BT adapter, but not a USB hard drive, and an ethernet port.
The USB ports supply 500 mA.
I was talking about the connector on the radio being dirty / cracked. The plastic divider/tongue.
Then why does my old laptop do fine with a 8 gig SDHC 10 card but not even see a 32 gig SDHC 10 card that both work fine in my PC and my Raspberry Pi.
If one drive stops working will the other drive work?
The USB port in the HU is broken. Cheaper to replace the HU than repair it. I can't think of anything that would be time related on that scale, usually a heat related problem fixes itself in a few minutes. A lot of people have reported USB problem.
From Wikipedia:
From Wikipedia:
The USB ports supply 500 mA. From Wikipedia:
So, the short answer is yes, USB ports do provide power. Try plugging a 2.5 laptop HD into that raspberry pi if you want- it'll run without an external power adapter off of 500mah no problem. I don't understand why this is necessarily relevant to the question- it seems more like you're trying to debate the efficacy of my testing and I don't think it's conducive to the issue.
Nope. The port doesn't provide any power whatsoever during these periods of time, so nothing is going to work. The hot plug isn't hot.
With these people that you've seen reporting USB issues, what were their solutions (other than shift-canning their entire head unit)?
