OnStar/SiriusXM Antenna Rubber Mast Removal
Old 05-05-2018, 08:36 PM
banjo's Avatar
The rubber antenna mast on the back of my 2009 roof .. can it be easily removed? If so, how? There is no tab release and unscrewing doesn't seem to want to work with medium force. The rubber mast is attached to a moveable circular part on the main plastic housing. However, this assembly moves only very slightly when turned. Is it just stuck or what?
banjo is offline
Old 05-05-2018, 10:14 PM
Technical Moderator
It is probably a twist lock thing. Push & twist. That's what the parts catalog says.
donbrew is offline
Old 05-06-2018, 02:38 PM
banjo's Avatar
OnStar/SiriusXM Rubber Mast Removal
Thanks, Don...Push and twist does not work...Any other ideas?..Banjo
banjo is offline
Old 05-06-2018, 07:36 PM
I just tried it. It just unthreads, counter-clockwise. No push necessary.
RJ_RS_SS_350 is offline
donbb82
04-18-2016 09:58 PM
ioweejun
06-14-2009 01:01 AM
Orange
09-29-2008 01:51 PM
Lee3333
09-04-2008 06:18 PM
jerij
10
01-24-2006 07:59 PM
Quick Reply: OnStar/SiriusXM Antenna Rubber Mast Removal
