Where is the 12v battery wire
I moved your thread to a more appropriate area of the site.
The BCM controls voltage, so there’s not a direct wire from the battery, you can tap into a red wire under the HVAC controls inside the interior fuse panel door. Keyed or hot ? Or go right back to the battery.
These guys can help
https://www.crutchfield.com/learn/20...rolet-hhr.html
They should have wiring instructions
These guys can help
These guys can help
These guys can help
okay that’s the wire I was talking about thank you but wdym by keyed or hot
My suggestion would be to use the pink wire out of the radio harness for 12 V power when the radio is on. Or as Oldblue suggested any of the unused fuse positions on the BCM are switched with the key. Depends on how many amps you need to supply. It might be advisable to use a relay.
