Where do I get power????
Old Apr 3, 2010 | 09:14 PM
sideout94's Avatar
I have purchased an overhead drop down DVD player for my HHR. I have cut into the headliner and found the rib to mount the player. What I am having trouble with is where do I get the power needed to make the player work? According to the instructions I need to run 12v (constant), ground, and acc. (switched) wires. I have thouhgt about tapping into the dome light but I cant figure out how to get that out and if the proper wiring is available there? If i run the wiring to the dash where would be a good tap-in location? i will post pictures after it is installed.
Old Apr 4, 2010 | 10:06 AM
chasfreeman's Avatar
power source
Remove the trim panel on the A pillar passengers' side; you find a wire loom running down it. Wire tie to the wire loom, run wire under dash to fuse panel and then from auto parts store use Littlefuse add-a-circuit. this will give you a fused protected circuit and not over load exsisting one. Dropping headliner is pretty easy see links in this forum.
Old Apr 4, 2010 | 10:27 AM
harleysshhr's Avatar
A new member with 10 posts - great answer- congrats
Old Apr 4, 2010 | 09:36 PM
sideout94's Avatar
Thank you
Got the player mounted and ran wires forward down drivers side windshield pillarand under dash over to center console. Wired it in with my aftermarket stereo with a fuse in the headliner and one behind stereo. works awesome and looks great will add pictures later to dark to take them tonight.
Old Apr 8, 2010 | 03:59 AM
ufvj217's Avatar
yea i'd like to see pics as well!
brazor06
Dec 11, 2022 07:59 AM
desmonda
Dec 24, 2014 07:43 AM
Pretzel
Oct 3, 2014 10:37 AM
allij0812
Dec 12, 2013 11:16 PM
rendon47
Dec 23, 2011 02:26 PM
