Where to mount second 6.5" on the door?
Old Jan 5, 2022 | 12:43 AM
hhrumadbruh's Avatar
Dont care about looks. Using junk yard door panels for fabrication and mock-up.
I want to add a second 6.5 to each front door...or somewhere else.
rears are not used.
What spot has the most room behind it that would allow me to mount a 6.5" outside of the door panel?
Probably going to keep a mid range on 80hz in the door for mid bass and run a pro audio 6.5 in the door at 250hz just for louder vocals.
will be acquiring a zed leviathan 2 soon hopefully so I'll have 2 extra channels.
anyone added 2 6.5" to the front doors? Or kick panels? Or???
Old Jan 5, 2022 | 09:49 AM
I would put the bass under the seats, since you really just feel it and the mid range in the doors tweeters in the pillars.
Old Jan 5, 2022 | 10:06 AM
bass is in the trunk. Mid bass is 45~ hz and up so it uses the door as a box. Second 6.5 from 150-200hz and up for loud vocals. Tweeters about 3 inches under the air bag label/screw cover on a pillars.
dougcjohn
"How To" Tutorial Library
Mar 12, 2019 01:57 PM
hhrumadbruh
Mar 27, 2016 08:19 AM
hhrlover101
Oct 5, 2012 12:23 AM
Biff
Dec 29, 2008 09:00 PM
SIHHR
Nov 25, 2005 12:40 PM
