where is my amp???
Old Jul 16, 2007 | 11:30 PM
robbied's Avatar
where is my amp???
Hey, Before i start tearing my car apart, Where is the 260watt amp? second, does it have RCAs running into it so that i can hook up an after market amp, or do I have to run a new line, if so, is there RCA hookups on the stock deck. btw, I did get the sun and sound package. I look forward to hearing from everyone. thanks, ROb.
Old Jul 16, 2007 | 11:33 PM
That's a trick question right?
There is no 260 watt amp. There is a TOTAL of 260 watts.
I don't know all the exact details on how the power is split but the sub has its own amp attached to the box in the rear. I believe the HU drives the front speakers.
Old Jul 16, 2007 | 11:37 PM
erf2u's Avatar
It is in the rear left panel next to the subwoofer! not sure about the RCA connectors, but sure someone here will answer that for you.
And welcome to the site!
Old Jul 17, 2007 | 12:17 AM
shaginwgn's Avatar
No rca connectors if you want to add another amp and sub. you are better off getting different h/u so you will have rca's but to get different h/u you will need a metra gmos-lan-04 harness runs around $100-$140.
Old Jul 24, 2007 | 12:12 AM
robbied's Avatar
thanks for the help. where would i get this harness.
