Wiring for Pioneer radio into 09 HHR
Old Feb 12, 2020 | 05:29 PM
A reason for all speakers failing at once is the radios protection circuitry; if a speaker short circuits (as opposed to open circuit) the radio shuts all speakers down to protect itself.
Old Feb 12, 2020 | 08:54 PM
TheShadeTreeFixitMan's Avatar
Been there, done that. If you replace the radio, get the correct adaptor, if for no other reason that you can add value by assuring the next buyer that they can just plug the original radio back in if they want to.
I've received great advice about audio on these forums. Both of my LS's with base radio/speakers had door speaker failures, one by one, intermittently at first, them complete. And exactly as I expected from the experience voices here, the little high-frequency "presence" tweeters in the A pillars kept working, giving a tiny, tinny, distant sound.
Almost any POS aftermarket speakers will be better than the base OEM's. I got lucky and found 2 pairs of not terrible $40/pair 6" speakers on closeout at $20/pair.
I'm not convinced that the feeble base radio didn't contribute to the demise of the stock speakers though - inadequate power and/or too-skinny wires and/or poor connections will trash speakers (clipping), especially cheepies, according to my limited understanding of these matters. Anyway, I retrofitted a garage-sale high-quality (for its time) double-DIN unit complete with navigation and other frills, picked up an OEM subwoofer/amp and grill from a boneyard, stored the amp (too many wires) and bought a cheap little amp for the subwoofer only. Pretty satisfied with the results since I don't run high volume, HUGE improvement over original.
Then I sold the car. ¯\_(ツ)_/¯
Still have one LS with bad speakers to fix. The other two wagons have Pioneer "enhanced audio."
Thanks for the input. Would all the speakers quit at once and then sometimes come back on? I am going to buy the interface at any rate, and will check into the factory installed amplifier. Even second hand they can be pretty pricey...
I found a 2 channel amp for under $10 which will suffice if I need to go that route.
I will post my results when I get it all back together and working properly.
Thanks to all who have contributed to this point.
Old Feb 13, 2020 | 07:53 AM
The speakers all failing, yes it has happened, moisture in the door cavity. Kills the speaker coils.
Old Feb 13, 2020 | 08:12 AM
Didn't I explain that in post #21?
Old Feb 13, 2020 | 09:30 AM
Lethal Tendencies's Avatar
No power to the rear amp will cause that as well
Old Feb 13, 2020 | 09:52 AM
  #26
Originally Posted by donbrew
What sub woofer test? Is there a "Pioneer" label on the rear quarter trim? The usual problem that you describe is faulty speakers, they are a very frequent failure point.
This question about the Pioneer label in the cargo area was asked a week and a half ago. The answer will tell if you have a factory amp or not.
Old Feb 13, 2020 | 12:34 PM
  #27
I am going to check into that. I am waiting for warmer weather now and hope to have that early next week. Thanks so much.
Old Feb 13, 2020 | 12:35 PM
  #28
I didn't see that post, but thanks so much.
Old Feb 14, 2020 | 11:39 AM
  #29
Cat Man HHR's Avatar
What you said is interesting.
Being curious, did you find that in a repair manual ?
Old Feb 14, 2020 | 12:02 PM
  #30
Good question.
