Wiring for Pioneer radio into 09 HHR
Old Feb 14, 2020 | 02:45 PM
  #31
Originally Posted by Cat Man HHR
What you said is interesting.
Being curious, did you find that in a repair manual ?
yes, note it is when a speaker SHORTS (wires connecting to opposite polarity) not when one OPENS (wires broken). Either can happen from water damage.
Old Feb 15, 2020 | 10:54 AM
  #32
PulpFriction's Avatar
Originally Posted by TheShadeTreeFixitMan
Would all the speakers quit at once and then sometimes come back on?
That's what happened to me. Sort of. You may not immediately notice when just one speaker quits. My problem was definitely progressive but not linear, speakers would work intermittently and i can't say the problem didn't move around. . In the final stage just one door speaker worked, intermittently, and then nothing but the a pillar tweeters.
Additional non-expert analysis - crappy insulation in the coils combined with "clipping" related transients caused by inadequate power and inferior electronics causes arcing that will burn the insulation and/or the wire, but not at low volumes; the more you "crank it" the worse it gets, and an old rule is to never turn your audio up more the 1/2, especially with cheap stuff.
I also noticed the stock speakers had pathetically weak magnets; maybe a physicist or a speaker expert knows if that could contribute to the problem.
This sort of damage would seem to plausibly explain the gradual escalation of the problem, but could also explain an abrupt failure of one or more speakers.
As long as my wife, who can't stand loud, drove the car, no problem. I like to turn it up a bit and when I began driving it, the trouble started, so...
Old Feb 21, 2020 | 07:02 PM
  #33
JBort's Avatar
Audio System Help Needed-no sound from speakers
I've installed stereo systems for many years but this one has me baffled; 2010 HHR SS w/pioneer stereo. I replaced all the speakers and subwoofer with new high end speakers, replaced the head unit with a JVC double din. I installed the steering wheel adapter from Crutchfield. (I even replaced the CRUX adapter with a new one).
Everything worked fine for a week. I went out one evening and no sound. Tuner was working, USB was working, just no sound. Volume control showed volume up and down.
As a test, I wired a loose spare speaker to the head unit output speaker leads Sound!! I tried putting the stock head unit back and no sound,
At this point, I'm willing to bypass everything to wire the speakers to the head unit.
Can I cut and crimp the wires from the factory harness (2-plugs)?
Anything?
Old Feb 21, 2020 | 07:42 PM
  #34
Check fuse #6 in the interior fuse block.
Old Feb 21, 2020 | 09:26 PM
  #35
JBort's Avatar
Fuse #6 has power to both legs. (I was really hoping this was the problem; makes sense)!
Old Feb 21, 2020 | 10:45 PM
  #36
What does "both legs" mean?
Fuse #6 powers the amp. Fuse #23 powers the radio and a few other things. The radio/HU acts as a pre-amp.
Old Feb 22, 2020 | 07:29 AM
  #37
JBort's Avatar
Both sides of Fuse #6 showed 12V; Power in, power out. Fuse is good.
Old Apr 9, 2022 | 08:26 PM
  #38
Basshead1980's Avatar
12 volt switched
Originally Posted by Oldblue
I suggested an adaptor because of my experience installing radios, sound systems, in cars and trucks over my 50 plus years in the car industry. Also the sites many threads about people hooking up a radio in the cut and splice method, which 9 times out of 10 offered poor results.
I’m sure you have the skills to wire it up anyway you want, but you did log into the site, you did ask a question, and I offered my version of a solution. If it’s not what you wanted to see , then that’s fine.
The HHR will tell you it doesn’t like it’s wires cut , it’s BCM will reject your intrusion into its .
At least I can sleep at night knowing I gave you good advice.
  1. I recently purchased an interface for my 2009 Chevy HHR because I couldn't find the red wire on the wiring harness I had bought. I hooked up the interface like it said and my radio still works even when my car is off and the keys are out. The problem with this is it keeps running my battery dead! How can I fix this to where my radio doesn't draw juice from my battery at night?
Old Apr 9, 2022 | 08:33 PM
  #39
By wiring the GMLAN adapter in. There is no switched power in the radio harness. If you can live without the turn signal and key in chimes you can take switched power from any of the "spare" fuse positions in the inside fuse box. Or, get a GMLAN adapter that uses the digital signal from the BCM to turn the radio on.
Most after market radios need a Hot input and a Switched input.
Old Apr 9, 2022 | 08:43 PM
  #40
Thanks I never thought about using an empty space in the fuse box
