XM radio
I just got a 2008 HHR LS 30,000 miles I was wondering how i could get the factory XM set up replace radio with one that is got it? I have on star so i have 2 antanas on the top one in front and one in rear is this something i can do fairly easy? has any one done this?
As long as you have RPO Code UE1 and don't have U1C you can add the module below. RPO Code list is located in the glove box.
XM Radio Upgrade Kit. Part Number: 17800594 |
I just got a 2009 HHR 2LT and want to add XM radio to it. I have installed one in my 2005 Trailbalzer that I got on ebay with no problems. I want to install the same kit in this HHR and want to know if it will work. The kit says it will work with or without OnStar. I emailed the seller(whom I purchased my trailblazer kit from) and they said that it will not work UNLESS you have OnStar. I DO NOT have OnStar so I am not sure. I dont care to have the antenna in the back of the roof, I can just hide the antenna wire and run it to the top of the roof. So I want to know if the plug and play kit will work with my HHR without OnStar. I also have the correct radio for this to work. THe RPO Code is UE0 as listed in my glove box. Someone please give me a clear answer if you can. Here is the link for the ebay auction.
http://cgi.ebay.com/ebaymotors/2006-...fAudioQ5fVideo Thanks, Kevin |
Originally Posted by JUSTKEV
(Post 480062)
So I want to know if the plug and play kit will work with my HHR without OnStar. Kevin
thanks for all your help
Originally Posted by Nurseman27
(Post 475484)
Look for the RPO codes in the glove box, its a label pasted in there, kinda hard to read so grab a flashlight.
(Post 480062)
http://cgi.ebay.com/ebaymotors/2006-...fAudioQ5fVideo Thanks, Kevin Blue |
The wiring (and module) is probably not there – GM, as well as all manufactures, are trying to save weight and thus increase gas mileage. So nothing extra is added to vehicles anymore.
It is possible Kevin’s vehicle was a fleet or rental vehicle and thus was not equipped as such. My base level 2009 LS came with both XM and OnStar – both of which I have switched off. Also see: https://www.chevyhhr.net/forums/show...9&postcount=11 for that "UE0" RPO code. Clearly states: "UE0 Communication System - Vehicle, G.P.S. - Not Installed" |
