XM radio
XM radio
I just got a 2008 HHR LS 30,000 miles I was wondering how i could get the factory XM set up replace radio with one that is got it? I have on star so i have 2 antanas on the top one in front and one in rear is this something i can do fairly easy? has any one done this?
I just got a 2009 HHR 2LT and want to add XM radio to it. I have installed one in my 2005 Trailbalzer that I got on ebay with no problems. I want to install the same kit in this HHR and want to know if it will work. The kit says it will work with or without OnStar. I emailed the seller(whom I purchased my trailblazer kit from) and they said that it will not work UNLESS you have OnStar. I DO NOT have OnStar so I am not sure. I dont care to have the antenna in the back of the roof, I can just hide the antenna wire and run it to the top of the roof. So I want to know if the plug and play kit will work with my HHR without OnStar. I also have the correct radio for this to work. THe RPO Code is UE0 as listed in my glove box. Someone please give me a clear answer if you can. Here is the link for the ebay auction.
http://cgi.ebay.com/ebaymotors/2006-...fAudioQ5fVideo
Thanks,
Kevin
Thanks,
Kevin
thanks for all your help
Thanks,
Kevin
Thanks,
Kevin
Blue
The wiring (and module) is probably not there – GM, as well as all manufactures, are trying to save weight and thus increase gas mileage. So nothing extra is added to vehicles anymore.
It is possible Kevin’s vehicle was a fleet or rental vehicle and thus was not equipped as such. My base level 2009 LS came with both XM and OnStar – both of which I have switched off.
Also see:
https://www.chevyhhr.net/forums/show...9&postcount=11
for that "UE0" RPO code.
Clearly states: "UE0 Communication System - Vehicle, G.P.S. - Not Installed"
Also see:
Sno White
"How To" Tutorial Library
11
Aug 26, 2009 05:48 PM
