Xm radio tuner
Um Excuse me...
If you have OnStar which apparently you do then cool, BUT if you do NOT also have the XM radio Tuner installed then you are SOL .
You will know if you have XM from the factory by checking the RPO Codes on the Glove Box Door Sticker, you are looking for code U2K indicating XM.
Without it you will need to buy an XM Tuner module and install it to get radio integration - this MAY also require a dealer reflash to get the tuner to talk to your BCM on the LAN.
Not the best news I know, but I am going through the same situation now on my '08 HHR SS - I needed to buy the XM from a bone yard or Ebay typically $35.00-$50.00 Then install flash and listen to smooth XM. tunes...
Not quite true sir. The shark fin antenna is used for both OnStar and XM.
The hint about RPO codes was cited many times. You can also just push the button on the radio to check for it.
I don't know for sure but I think if the Onstar is there the XM wiring is there. OnStar was standard equipment (most years) except when ordered deleted. I know the 2 HHRs I had were former fleet cars with no OnStar and there was no wiring back there.
Thanks! I'll find out for sure this weekend. I'll be burrowing my way into that area to swap out my non-Bluetooth OnStar VCIM for one with Bluetooth which should be delivered on Friday. I think I know what needs to come off of the panel to get to it, according to Mitchell anyway. The odd thing is that it says the first thing to remove is the "window plug", yet I've read posts here that seemed to indicate that there is a lot of other things that need removing before you can get to that plug. I guess I'll find all that out to. If anyone knows what's holding that window plug on the quarter panel, I'd appreciate knowing that, to save time and too minimize the chances of doing damage.
