Adjusting Brakes
Mechanic A says if the rear drum brakes are not adjusted properly it will cause extra wear on the front disc brake pads.
Mechanic B says not so because the PROPORTIONING VALVE will compensate and apply equal pressure to all 4 wheels, and NO premature wear. who is correct? Mechanic A or Mechanic B |
B on a car with functioning rear adjusters, A for our beloved truck lets.
Mechanic A.
Mechanic B needs to go back to school. The proportioning valve does not adjust to compensate for this. It is a "set" proportion for the lack of a better term. |
